Old 08-10-2016, 07:46 PM   #1
bornn57
front in suspension suggestions
I have added PS, PB, and AC to my 57 3100. Everything else is all original. It seems the extra weight or just age is causing what I would refer to as "bottoming out" when I hit larger than average bumps in the road. No problem with the rear end. Any suggestions on how I can easily beef up the front suspension?
bornn57 is offline   Reply With Quote
Old 08-10-2016, 08:09 PM   #2
mongocanfly
mongocanfly's Avatar
Re: front in suspension suggestions
Replace springs..over time they will loose their rating and sag.if theive never been replaced they are about 60 yrs old..new shocks will help as well..
Old 08-10-2016, 08:19 PM   #3
bornn57
I have replaced the shocks and it helped. Was hoping to avoid $$$ leaf spring replacement. thanks for your post
Old 08-10-2016, 08:22 PM   #4
mongocanfly
I have a 57 international and the spring on the drivers side collapsed...so they will give out over time
Old 08-10-2016, 09:04 PM   #5
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
You might be able to have them re-arched, if you can find someone who still does this.
ChuckDriver is offline   Reply With Quote
Old 08-12-2016, 10:25 PM   #6
my56chevytruck
my56chevytruck's Avatar
been there done this. you want a good ride? spend the money on new springs and you'll enjoy the ride for years to come. Make sure the springs are the correct weight for the engine you are running..
RUBBER DOWN AND HIT THE ROAD!!!
1940 Ford Dlx Coupe
1969 Mach1
my56chevytruck is offline   Reply With Quote
