Old 08-14-2016, 11:18 AM   #1
Mrturner1
What's the difference?
So I have a 1970 C10, and it came from the factory with an L6 and 4 speed but somewhere along the lines it got swapped for a 355/th400 setup by the previous owner. I got an oil pan gasket for it yesterday and the arch that goes over the timing cover wasn't big enough. I took the gasket back (fel-pro permadry btw, the blue one peice) and ordered one for a 75-85 Chevy small block and it fits perfectly. What does this mean for my block and rotating assembly? Is it gen 1? Something else maybe? The crank journal is clearly bigger
Mrturner1 is offline   Reply With Quote
Old 08-14-2016, 11:46 AM   #2
truckster
truckster's Avatar
Re: What's the difference?
It's Gen 1 - Everything up to the LT1 engine is considered Gen 1. There were manufacturing differences over the years.
truckster is offline   Reply With Quote
Old 08-14-2016, 12:03 PM   #3
Mrturner1
So what's different about this one? The larger journal is a plus correct?
Old 08-14-2016, 01:42 PM   #4
truckster
truckster's Avatar
As far as I know, the journal size changed to 2.45 some time in the early 60s and stayed the same. There were a couple of different thicknesses of front cover/oil pan gasket, but I believe that was due to the difference in the channel in the front cover.
The biggest difference between earlier and later Gen 1 SBC blocks would be the later change to 1-piece rear main seal and provision for roller cams.
Old 08-14-2016, 04:34 PM   #5
Mike C
Mike C's Avatar
There were two different versions of oil pan stampings. Regular gasket sets usually come with both sizes of rubber pieces and use the same cork side pieces.
In late '70's (1978 I think) GM switched dipstick to passenger side of block from driver's side and in '86 went to 1 piece rear seal.
All of these things require a different oil pan gasket.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 08-14-2016, 05:21 PM   #6
GRX
GRX's Avatar
Crank journals are the same. Like Mike said ^^. Difference is in the pans. First one was for the older type pan. Thicker gasket required after 1975.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
