Old 08-14-2016, 07:42 PM   #1
69restomod
69 swb turbo Ls swap
Bought this gem today it's an 02 2500 hd Silverado 4x4 with the 6.0l and 4l80e got the whole truck for 1500$ with 160,000 miles plan on doing rods and Pistons with ls3 heads a boost cam and a s480 turbo with maybe around 14 pounds of boost. Haven't done an Ls swap yet in our trucks if anybody has any suggestions on motor mounts and motor mount brackets and what accessory drives works in our trucks that would be great oil pan etc. will post as many pics as I can along the way.
69restomod is offline   Reply With Quote
Old 08-14-2016, 07:44 PM   #2
69restomod
Re: 69 swb turbo Ls swap
Picture of the motor
Old 08-15-2016, 10:45 PM   #3
69restomod
I build double walled water cooler stainless steel turbo kits for high end jetskis on the side and I am thinking of doing water cooled housings on my kit to keep down under hood temps let me know what you think!
Old 08-15-2016, 10:48 PM   #4
69restomod
This is one of the Borg Warner efr turbo housings I build it would be very similar to this
Old 08-23-2016, 04:58 PM   #5
69restomod
Got the front clip off driveshafts out and transfer case off pretty close to pulling it out
Old 08-23-2016, 04:59 PM   #6
69restomod
4l80e with the transfer case off
Old 08-24-2016, 02:47 AM   #7
boynton
boynton's Avatar
I used early classics mounts in mine they worked well but my swap was a 2wd. they make a complete kit with everything for just over $200 that has poly mounts. I used the stock accessories and the stock pan. I have some photos on my one owner short step build
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 08-24-2016, 10:13 AM   #8
69restomod
Sorry guys this is my truck it is going in!
Old 08-24-2016, 10:40 AM   #9
69restomod
Here is the current sbc engine setup in the truck now that I will be pulling out here shortly
Old 08-24-2016, 12:11 PM   #10
boynton
boynton's Avatar
the mounts I used will work fine for you. I would set the motor back about an inch from the stock v8 holes with those mounts. are you going to run your current transmission?
1970 SWB Step-Side
Old 08-24-2016, 12:25 PM   #11
RRR18
RRR18's Avatar
Watchin
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 08-24-2016, 12:28 PM   #12
69restomod
Ok great I'll look up the early classics setup and I'll check your pictures out cause I would like to use the stock pan and all the accessories air conditioning compressor alternator etc. and I am going to be running the 4l80e that is hooked to the 6.0l I'm gonna have the output shaft changed to the 2wd setup
Old 08-24-2016, 01:23 PM   #13
69restomod
So I was just looking at the early classics late mode Ls swap motor mount kit and I was wondering does it have adjustment front and back like a lot of the Ls swap motor plates?
Old 08-24-2016, 01:49 PM   #14
boynton
boynton's Avatar
it does not but it worked well for my application. I also used their 4l80 trans mount to keep the pinion angle good
1970 SWB Step-Side
Old 08-24-2016, 02:23 PM   #15
69restomod
Ok great well sounds like I got the motor mounts figured out! Did you have to modify the trans tunnel at all to fit the 4l80e in your truck?
Old 08-24-2016, 07:00 PM   #16
69restomod
Got the main engine harness disconnected from the fuse panel and got all the power steering lines and cooler off all the heater core lines and Ac lines and trans cooler off, the only thing left is fuel rails and motor mounts, but have to take the pup to dog training and have my girlfriends suprise bday dinner tomorrow night with family and her actual bday dinner Friday night with friends so I will be pulling it out Saturday morning! I am interested in where you guys are mounting the computer? In the cab? On the fender well? And what all is involved in getting the motor running in the truck as far as wiring?
Old 08-25-2016, 01:45 AM   #17
boynton
boynton's Avatar
I did. I cut out the low hump and welded in studs for a high hump and then bolted it in just like factory. I use a company called lsx unlimited to do my harness and pc tuning.lsx unlimited is based out of Alvarado and has done well for me in the past they are currently working on another harness for me that I will pick up on Saturday. there is a guy on the board that does it but he never got back to me so I don't know anything about them. if you want to do the harness yourself go to ls1.com they have all the pinouts there.
1970 SWB Step-Side
Old 08-25-2016, 08:06 AM   #18
69restomod
Ok cool I was kind of thinking I might need to change to a high hump for the 4l80e but wasn't sure, and I'll have to check out lsx unlimited I think I might follow those guys on Instagram, I actually just rewired my whole truck a couple months ago with a harness from haywire so hopefully I won't have to change to much of what I already did lol I'm thinking of running a racepak for my gauge cluster and getting rid of my auto meters, I read over 3 or 4 pages of your 6.0 ls build this morning before look and it looks awesome man!
Old 08-26-2016, 05:23 PM   #19
boynton
boynton's Avatar
Thanks. it makes me smile every time I get into it. I ran a relay for my starter because I heard the ls starter solenoid pulls too many amps and can burn up the switch. not sure if it is true but I went with it since a relay is better than replacing my switch.
1970 SWB Step-Side
Old 08-30-2016, 07:31 AM   #20
Overdriven
I'm not sure I'd bother with water cooling the turbine housing or the up pipe. On jet ski it's needed due to the cramped space and it doesn't hurt performance due to the short amount of piping between the engine and the turbo. For applications like ours most just use header wrap on the piping and maybe a turbo blanket if it's close to something. The wrap keeps the heat in the pipes, both to lower under hood temps and to make sure the turbo gets that heat to spool as quick as possible. Water cooling the housing and piping may not degrade performance much if at all, but to me it seems like an unnecessary complication for our style of application. Nice fab work though, can't wait to see the kit you come up with.
I'm going to be doing a similar setup in my truck but I'm not ready for action yet and still in the planning stages. Haven't done too much research on fuel systems yet but recommend visiting LS1tech, and sloppymechanics.com and watching his 6.0 Colorado vids. A common combination is using 80lb injectors with a Walbro 400 which if I recall correctly is good to about 600whp. If you want to go further than that you're going to need more injector and fuel pump. Sloppymechanics likes to go the least expensive route and runs a pair of Walbro 400's T'd into the same line instead of a big single pump for his 800whp Colorado.
While there's no reason you can't keep your Summit fuel cell, you can't run an in tank pump with it. In tank pumps will be quieter, run cooler and can last longer because of it. You can't keep your QuickFuel pump (not enough pressure for EFI) so you're redoing most of your fuel system, if you're going to replace the tank/cell now is the time to do it.
Overdriven is offline   Reply With Quote
Old 08-30-2016, 07:40 AM   #21
69restomod
Yea after I talked that idea over with the guy I work with on the jetski turbo kits he said it prolly wouldn't be the best idea so I scratched that idea pretty quick after thinking it up , and yea I knew I wouldn't be able to use my quickfuel pump it's only good for 14 psi for a carbuerated setup, I've watched some of sloppy mechanics builds and it is pretty cool what he does on a budget, I like the idea of the twin walboro pumps into one line, I guess as of right now I need to figure out whether I'm gonna run an external or in tank setup, I'd like to get away from the noisey external if I could my quickfuel I run now is very loud
Old 08-30-2016, 08:56 AM   #22
Overdriven
It sucks when you already have a tank/cell, but if it was me I'd ditch it and go in tank. Afterall, you're ditching your current engine for a more street able setup, why love with a noises fuel pump. There's other options besides a custom tank too, any of the rear mount conversion tanks for our trucks designed for fuel injection would be fine. Mount the pump(s) of your choice to the thingy that drops in (forget what that's called) and you're golden. You're already wired up, just need to make sure it's sufficient for the draw.
Old 08-30-2016, 09:56 AM   #23
69restomod
Yea man for sure I agree 100% I just found this drop in aeromotive setup which you can run up to three drop in pumps which one single is good for 700 hp forced induction efi and two it says is good for 1400 hp and I could retrofit it into my fuel cell!
Old 08-30-2016, 10:02 AM   #24
69restomod
My truck is patiently waiting for its new turbo Ls swap 🤑🤑
Old 08-30-2016, 01:10 PM   #25
shores6
shores6's Avatar
On my turbo build, I went with the Boyd's fuel cell with the in tank aeromotive a1000. All -8 line, y'd going into the fuel rails, with the regulator mounted to the passenger side rail and then returned to the tank. The A1000 pump should be more than sufficient for what I'm going to be running. If you dont wanna spend the money on it, I have a couple friends that have ran the dual walbro 255 with good success.
Todd
https://www.instagram.com/shores6/
Project: Boosted Blucille. '70 C10 SWB PB Fab, LS2 S480 - http://67-72chevytrucks.com/vboard/s...d.php?t=700419
shores6 is offline   Reply With Quote
