carburetor is leaking from top gasket
I was trying to fix the throttle because it sticks. It'll idle at 1000 to 1200 and when I goose the pedal it drops to 600. So I greased up the linkages and it wasn't sticking as bad, but when I was on my way back home the truck died and it was leaking pretty bad from the top carburetor gasket.
When I was greasing the linkages, I noticed it was wet on and around the carburetor to suggest that this isn't the only time it has happened, maybe just not as bad. 1971 c10 with monojet carb. Any help would be appreciated. Thanks |
#2 | |
Cluster King
![]() Join Date: Nov 2012
Re: carburetor is leaking from top gasket
Carburetor kits are cheap, and a new float not much more. Cheap insurance against an under hood fire waiting to happen! Is this an L6? Shouldn't take but a few minutes to go through that one.
Ben ![]()
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time" ![]() “Serious Black” my 1971 Short Bed Fleetside Sold to an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten” |
#4 | |
When I saw it spilling over, I thought it was going to catch fire!
Thanks for the suggestions. I'll be tearing that sucker apart today and also picking up some fire extinguishers. |
I opened the carburetor up and I noticed that the float would snag sometimes while moving it up and down. I couldn't adjust it so it would stop snagging so I ordered a new brass float with the rest of the kit. I hope it'll fix my issue. Other than some fine copper color metallic flakes at the bottom of the float bowl, the carburetor is pretty clean.
