08-20-2016, 03:36 PM | #1 |
Another inner fender question: NOS.
It looks like the NOS deal on the two front inner fenders is going to pan out.
What do you guys think about this? I can run both over to the media blaster for glass bead work then a coat of epoxy primer. What say you? After that dries and I can haul them back, the undersides get Rhinolined (or undercoated) and the top sides get painted. What do you think? (Would Rhinolining give me any trouble with those U-clip nuts that attach inner to outer fender)? |
08-20-2016, 05:20 PM | #2 |
Re: Another inner fender question: NOS.
I'm redoing a 87 and my plan is to spray both sides with por 15. Then to linex the underside. I would think you could make the clips work. On an 87 the clips go on the fender not the inner fender.
'69 CST Short fleetside Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress) '87 V10 4x4 Short Fleetside Quad Suspension and Dual Tanks |
08-20-2016, 05:22 PM | #3 |
You know, I guess the clips would go on the outer fender wouldn't they? Good news then! Thanks.
