08-23-2016, 03:47 PM | #1 |
Anyone using Lokar column shift linkage?
ACA 1800?
I'm finding the rod is too short by inches. Any solutions?
08-23-2016, 04:18 PM | #2 |
Re: Anyone using Lokar column shift linkage?
BigDave,
I bought the same kit from Summit, and had the exact same problem. I went to Ace Hardware and bought a threaded coupler and 5/16-24 threaded rod. Measure twice through all the gears and cut once. Problem solved. Just my solution. If you can return or exchange your kit, the paperwork with mine says a longer rod is available. I believe 26" vs. the 21" rod. Hope any of this helps. Roger
1971 K10 short bed step side, 5.3/th350/205, 3.73 gears |
08-23-2016, 04:29 PM | #3 |
Now i feel bad for cutting some length off of mine! my setup is a stock auto column and a 4l60e. I did have to bend the rod a bit to clear everything. install took maybe ten minutes.
My Build Thread Here http://67-72chevytrucks.com/vboard/s...d.php?t=457417 |
08-23-2016, 04:39 PM | #4 |
I used that kit with my ls swap 4L80 engine is set back about 1.5. One.was a tilt coloum the other stock
I also used it with a 350/700 and it reached with out extending.it.
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair http://67-72chevytrucks.com/vboard/s...d.php?t=625017 1967 C/20 6.0/4L80 Roofing Truck 1990 V2500 Suburban "Plow Truck" 2005 TAHOE DD |
08-23-2016, 04:41 PM | #5 |
I also had to bend the rod. Make sure its a hard bend not a sweeping curve of it will act like a spring
08-23-2016, 08:35 PM | #6 |
Well, I've ripped up the packaging. And yes the rod is 21 inches.
My truck is 4x4 with the 4L60 moved forward two inches. The rod is still way too short and I haven't bent it yet. I have factory pieces to model. I'm trying the Lokar to get better range out of my selector. To get N and OD to match up on the column indicator I barely can (and sometimes don't) catch park.
08-23-2016, 08:56 PM | #7 |
I found I needed the arm on the transmission to be clocked up a lot further than they suggest. Is there any body lift in your truck ? Its not a big deal to get a chunk of drill rod and put some threads on it if needed
08-24-2016, 12:49 PM | #8 |
Just in case anyone else runs into this. Here's a pic of the factory rod next to the 21" Lokar linkage. I've seen the Lokar mentioned fairly often but it is much too short in my 3/4 ton 4x4 application.
02-15-2017, 12:16 PM | #9 | |
R
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
04-16-2017, 03:13 PM | #10 |
I am converting my 3 speed manual transmission to a 700R4 and installing a power steering tilt column. Which length is correct for this modification?
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion |
08-21-2022, 07:21 PM | #11 |
what did you end up using? i have a 69 k20 and need to replace my shift linkage
08-24-2016, 02:17 PM | #12 |
i clocked mine at the 9 o clock position if that helps. seemed to work just fine.
08-25-2016, 09:32 AM | #13 |
+1 on clocking the tranny arm up higher - I did this on my last truck with the LS/4L60 swap, using that Lokar linkage, and not only did it make the linkage long enough, but it also shifted much smoother, and all the gears lined up with the indicator better.
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
