![]() Join Date: Apr 2015
two piece to one piece drive line swap.
My truck c10 has a th400 with and 1968 1/2 ton diff. Has a two piece drive line. Im all ready cut the frame and and welding everthing up (lond bed to short bed) just doing mock up stuff now.. I was planning on running the two piece. But if I could go one piece and pick one up from a wreck yard and have a shop cut it down.to fit.... what would I need to get this done...fit and vehicle wise to look for?.. done easy I guess.. lol..
#2 | |
Re: two piece to one piece drive line swap.
I have had several short beds and everyone of them had 2 piece drive shafts. The 2 piece is actually stronger and works good with a nice carrier bearing. But I'm sure there are more knowledgeable gurus on here that can guide you in the right direction.
![]() Join Date: Dec 2013
Too bad your so far away I have a stack of them .
![]() Check with DLtruck he was parting a bunch of trucks and is out your way . ![]()
![]() 1967 Factory short bed - Old school '71 - 350 / 4bolt / 487 heads / Edelbrock C3BX Muncie M-22 4 speed / Hurst Comp plus Factory 12 bolt posi 3.73 / 255-70-15 Smoothed firewall / Factory cowl induction Power disc brakes / power steering / 3.5-5" drop |
the boat guy
If you value your time and money have a new shaft made by a reputable driveline shop.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
Custom Sport W/T
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Take your measurements to the boneyard and you will find one. Change over U-Joints are available from Auto Zone if you need innie to outie joints. I am running a one piece from a Caprice of about 1990 vintage but not sure how long it will last as I have only put 334,000 miles on it...
