Old 08-26-2016, 10:42 AM   #1
MJN
MJN's Avatar
Factory/Dealer install engine oil cooler
Anyone have pictures of the engine oil coolers available on 73-80 trucks? Thinking of adding one to my '74 and would like to see one so I know what to look for, I've only seen pictures in the accessories brochures but not one up close.
'51 South Bend Model "9A"
'56 Chevy 3600 NAPCO
'08 GMC Envoy Denali
'12 GMC Sierra 2500HD Denali
'17 GMC Yukon XL
VCCA member #58596
http://www.nohrco.com
Old 08-28-2016, 09:18 PM   #2
gmachinz
Re: Factory/Dealer install engine oil cooler
This is a pic of my 86 w/factory engine oil cooler setup from a 1990 Suburban. I haven't seen a GM style one for a 73-80 truck but maybe this gives you an idea. The aluminum lines have crimped hoses and they route to a sandwich adapter above the oil filed and have (2) 45-degree fittings in which the lines thread onto. Fel-Pro is the only company I know of that offers a universal o-ring repair seal kit for these GM style adapters. If you find one, I'd suggest rebuilding the sandwich adapter seals.
gmachinz is offline   Reply With Quote
Old 08-29-2016, 08:32 PM   #3
johnwaynejeep
Here's the one from my truck. Remove the oil filter to access the two allen head bolts that hold the adapter to the block. There is also a mount at the front of the engine mount that stabilize the lines with a single bolt, 7/16 maybe. The soft lines pass through a 2x4 inch whole in the front cross member and then connect to the oil radiator.
O'Reilly's carries a general purpose oil filter seal kit that has about a half dozen rubber gaskets. One of these gaskets will fit the oil cooler adapter where it seats to the block.
Robert
1975 C10 - Huckleberry
2007 Jeep JK - John Wayne Jeep
Smittybilt front/rear bumper, 10K winch
Pacific Grove, CA
johnwaynejeep is offline   Reply With Quote
Old 08-30-2016, 10:13 AM   #4
bonehead
bonehead's Avatar
YEP, My 1991 suburban had the same setup. Install the new O-rings x2
past trucks:
1980 C-10 Silverado SWB
1961 C-10 custom cab LWB
1966 C-10 custom cab LWB
current truck:
1966 C-10 Panel SWB
bonehead is offline   Reply With Quote
Old 08-31-2016, 01:04 PM   #5
MJN
MJN's Avatar
Thanks guys, now I know what to look for!
'17 GMC Yukon XL
VCCA member #58596
Old 08-31-2016, 03:06 PM   #6
83GMCK2500
Goto this thread: PDF of Square Schematics & GM Training Manuals (link)
Scroll ~1/3 of the way down to the parts catalogs on .pdf, look for Catalogs 51 & 51A.
On page 79 of 51A you'll find a picture and list of parts for the 1974-78 "CK" Gas Engine Oil Cooler & Related Parts. The numbers there reference the group number the parts are found in Catalog 51 under, can then find the part numbers.
I often flip through the parts catalogs to see what was/wasn't available. If you're not interested in 100% correct as the '74-'78 parts may be hard to find you've always got the later stuff to look for like gmachinz posted.
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
