Old 09-01-2016, 12:04 PM   #1
67chevy_hotrod
67chevy_hotrod's Avatar
Factory style replacement wiring harness?
I am doing somewhat of a restoration and need to know where I can get a direct replacement style harness. Is there any that are plug and play? Stock looking stock fitting maybe just upgraded materials? What do you guys know?
1967 Chevy CST 10
1969 Chevy C/20 Longhorn
1969 K10 Suburban
1972 Chevy Cheyenne Super 10 turned K30 (sold)
67chevy_hotrod is offline   Reply With Quote
Old 09-01-2016, 12:26 PM   #2
YBNORML
YBNORML's Avatar
Re: Factory style replacement wiring harness?
American AutoWire. They sell factory style replacement harnesses for just about everything.
Jason.
68’ GMC shortbox
72' 2WD Blazer
67' LongBox C-10
InstaGram ybnorml67
Old 09-01-2016, 01:40 PM   #3
jeffahart
jeffahart's Avatar
Here's what I used. From AAW it's called the classic update, that, the proper crimping tool and some loom tape and you are in for a fun upgrade project. Note: the kit does not support the ammeter. I upgraded to voltmeter.
http://www.americanautowire.com/view...evrolet-truck/
White K20
jeffahart is offline   Reply With Quote
Old 09-01-2016, 01:53 PM   #4
davepl
davepl's Avatar
I used M&H (might be sold by AAW, now sure) and was actually very impressed with it. In fact of all the reproduction parts used in my restoration, it was probably the nicest.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-01-2016, 02:00 PM   #5
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I used and M&H front light harness and an engine harness. Both of which were bought from Wes at Classic Heartbeat (site sponsor).
Complete plug and play with all the correct clips, connectors, fasteners, and wrap. They even had the correct plastic wire channels for the fire wall and behind the radiator.
Good quality stuff.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 09-01-2016, 02:07 PM   #6
davepl
davepl's Avatar
The M&H units, if you're getting anything that includes the bulkhead connectors, are also properly packed with that horrible black goo that weatherproofs them as well.
Old 09-01-2016, 02:19 PM   #7
cypressbog
Go Pack Go!
www.gmcpauls.com sell M&H. Here's what his website says about the harnesses:
ALL WIRING HARNESSES DONE BY M&H ELECTRICAL FABRICATORS #1 IN REPRODUCTION HARNESSES
Made From Original Factory Blue Prints Using Original Wire Colors, Correct Gauge, & All Original Wire Connectors. Ships direct from supplier.
cypressbog is offline   Reply With Quote
Old 09-01-2016, 02:30 PM   #8
CUSTOM/10
CUSTOM/10's Avatar
AAW and M&H are almost identical, the owners of each use to be partners.
Both are very good products.
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 09-01-2016, 02:46 PM   #9
webfoot
Gary
+1, you won't be disappointed with either.
I just installed an AC harness in my truck, everything fit perfectly.
Running in place gets you nowhere fast.
-me
1968 GTO 4-spd covnvertible
1970 K-20 4-speed, factory AC.
webfoot is offline   Reply With Quote
Old 09-01-2016, 05:04 PM   #10
67chevy_hotrod
Thanks gents, I will look into M&h and aaw
1967 Chevy CST 10
1969 K10 Suburban
