09-03-2016, 08:52 AM | #1 |
Moderator
Large Flange Fender Bolts
Just some info on new fender bolts if your looking for them. The ones I find in the "kits" are not the "large flange" bolts. So if you would like the larger flange style bolts you can get them from Dorman products #700-302 they sell in 25 count (5/16"). Or a vendor on ebay called theboltbarn.
The bolt barn are not dog point but the Dorman ones are, Dorman are black oxide and the bolt barn are clear zinc. The bolt barn have them in 3/8" and 5/16".
09-03-2016, 08:18 PM | #2 |
Re: Large Flange Fender Bolts
Thanks Master Chief for the tip on the bolt sources.
I had to research dog point. Found it here. (https://www.boltdepot.com/fastener-i...rminology.aspx ) |
09-03-2016, 11:23 PM | #3 |
Subscribe
09-04-2016, 07:54 AM | #4 |
Registered Truck Offender
For just about ANY GM type body bolt,, check out page 19-20 of the Auveco catalog .The body bolts with the loose washer, and the ones with the threaded threads spiraled down to a point,, it's amazing how many different bolts GM used to tut these things together over the years.
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
09-04-2016, 11:10 AM | #5 | |
Never Ending Projects
. 1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
09-04-2016, 11:51 AM | #6 |
i use shoulder bolts all the time on hod rod or truck stuff /also like the hardened flange -locking nuts !! most guys building stuff use the "plastic lock nuts " that only last i time -on & off !! i always buy off the "net" very cheap and have them the next day in most cases PLUS a lot cheaper than a hardware store or fastenal and my man there almost gives them to me !!
09-04-2016, 12:19 PM | #7 |
A long time ago I bought the oversized head style from bolt depot. As mentioned these don't have the dog point as with the Dorman but I recall when pricing them back then that these were much less expensive too.
https://www.boltdepot.com/Flange_bol...e_5_steel.aspx Recently found a guy who sells bolts at all the local swap meets (Pomona, Long Beach) that had the original style black oxide type but I don't think he's online.
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
09-04-2016, 03:21 PM | #8 | |
Moderator
Edited - https://www.boltdepot.com/Flange_bol...l_5_16-18.aspx
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 05-05-2020 at 08:50 PM. |
09-04-2016, 08:32 AM | #9 |
Good info, thanks.
Keith SOLD - 1963 C10 Short Fleet 350/700R4 4/6 drop 1967 GMC Super Custom - Short Fleet COPO concept w/427 BBC T-400 w/Doug Nash overdrive 4/6 Drop, Buddy Buckets, etc... Frame Off (In Progress) I call it "Vulgar Display of Power" 1980 Silverado Original paint 49k Original miles 4/6 drop Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941 |
