09-05-2016, 12:48 AM | #1 |
Rear end help.
Hi all, I'm brand new to this forum, and I just picked up a 1965 C10 with which I'm going to do a custom build.
Right now I'm in the planning stages, and I admittedly know NOTHING about these trucks (eager to learn though!). It currently has a straight 6 and a three on the tree. I am looking at going with an LS motor, but I want to make sure the whole drive train can handle any power mods I throw at it. My question is, what can you folks tell me about the rear end? What type is it? Is it strong? Weak? What are the popular upgrades to it? If my best bet is a rear end swap (e.g. GM 12-bolt or something), are there certain donor vehicles that work best? I know you all have been at this for awhile, so I see no need to reinvent the wheel. Thanks! Bryan |
09-05-2016, 01:54 AM | #2 |
Re: Rear end help.
Most modern rear ends esp. posi units will handle the HP of an LS motor. Unless you do something crazy with your tires you won't have enough traction to cause a rear end problem in my opinion.
I installed an Eaton Posi 12 bolt and running 575hp currently.
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
09-05-2016, 08:15 AM | #3 |
Re: Rear end help.
The three speed and straight six didn't have a ton of power, so expect to find really high gears in that rear end. I think if I recall correctly the '61 I have came with 3.93:1.
Investigate wether you can get the gears you want and if axle shafts are available for it before you decide to keep or swap. B |
09-05-2016, 10:52 AM | #4 |
Re: Rear end help.
Is it not a 12 bolt now? Most common ratio was 3.73. That probably works with over drive. I currently have a 3.07 with straight through transmission.
09-05-2016, 10:55 AM | #5 |
Moderator
Re: Rear end help.
You have a great set up in the 65. It's a 8.875" 12 Bolt Truck Rear End (12T). You can get all new internals from this guy (I did), he even carries the 5 lug axles (you have to ask him):
http://www.ebay.com/itm/GM-12-Bolt-T...PDZYWCBXVAa1Dw You have the best panhard bar bracket on the frame for a longer bar already. http://www.quickperformance.com/GM-1...-12T_c_54.html
Master Chief, US Navy, Retired 1964 C10 Step-side Short Bed - In Progress 2009 2500HD Duramax LTZ 1948 GMC Panel 1956 Big Window Stepside 1953 5 Window Chevy Stepside 1932 Coupe New Seat Foam for Bench Seats? Last edited by The Rocknrod; 09-05-2016 at 11:05 AM. |
09-05-2016, 11:48 AM | #6 |
Re: Rear end help.
I suppose it could be a 12 bolt, I didn't think it would be. I would have looked, but it's in storage, oops. Thanks for the replies guys. Do you know how much power the 12 bolt is rated for?
1965 C10 - Got BIG plans for this little truck! |
09-05-2016, 11:45 PM | #7 |
60-66 Nut
Re: Rear end help.
All C10's from '63-'82 came with the truck 12 bolt. There is no reason to change the differential for something else. The 12 bolt will handle a lot of power. Of course how much will depend on how what tires you run and much money you want to put into it. In stock form a 12 bolt would easily handle ~400hp/tq. Your 12 bolt more than likely has 3.73 gears currently.
09-06-2016, 04:05 PM | #8 |
Re: Rear end help.
sorry to hijack but are the leaf spring GMC rears of that model year range also have 12 bolts?
1981 K10 (4.8 / 4L60E swap) 1982 C10 (5.3 / 4L80E swap) 1985 C20 Suburban (454 / 4L80E) |
09-06-2016, 11:47 PM | #9 |
60-66 Nut
Re: Rear end help.
The GMC's from '63 to about 1970 typically have the Dana 44. The 12 bolt was an option on the later years of that range. I do know that from '73-'82 the GMC's had 12 bolts and from '83 up had 10 bolts.
09-07-2016, 12:12 PM | #10 |
Re: Rear end help.
Thanks Captainfab, I went home last night and counted the cover bolts, only 10..
09-08-2016, 12:41 AM | #11 |
60-66 Nut
Re: Rear end help.
The Dana 44 that should be under your truck will have 10 bolts on the cover. It should look like this.
http://www.4wheelparts.com/Drivetrai...FUlrfgodYQ4Gjw
