09-12-2016, 11:20 AM | #1 |
3/5 drop - 5" tire sizes - what are you running?
Hi I recently picked up a 70 GMC C10 Long Bed and I plan on putting a 3/5 drop on it. It has nice steel 15x8 wheels on it (factory 6-lug - not rally rims) and I would like to run these with some period dog dish and maybe trim rings.
What sizes are you running and can you post a picture? Right now it has 31x11.50 in the rear and 31x10.50 in the front which of course, won't work. Also, if you have any input on my choice of drop, please chime in. Thank you in advance for your help.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
09-12-2016, 11:26 AM | #2 |
Re: 3/5 drop - 5" tire sizes - what are you running?
The title should say: 3/5 drop - 15" tires. oops
09-12-2016, 12:56 PM | #3 |
i think you will want a little more drop in front with 5 in the rear. here is mine... 4.5/5 drop, 15x8 245/60 4.25" bs front, 15x10 295/50 5.25" bs rear
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
09-12-2016, 01:03 PM | #4 | |
Springs and blocks rear with C-Notch in the rear?
09-12-2016, 01:00 PM | #5 |
this is how i bought my truck... 15x8 275/60's all around, 3/3 drop. not sure what the backspace was, but it had 1.25" spacers all 4 corners.
09-12-2016, 01:26 PM | #6 | |
09-12-2016, 01:24 PM | #7 |
first pic was 2.5" spindles & cut bbc springs (1 coil dropped 2.0") and 5" rear springs. i feel ok without a notch. second (older) pic was 3" cut front springs (also 1 coil but oem sbc springs a bit worn out) and 3" rears.
09-12-2016, 04:44 PM | #8 |
3 5 235/75/15 springs
09-12-2016, 05:05 PM | #9 |
09-12-2016, 05:17 PM | #10 |
09-13-2016, 03:07 PM | #11 |
Once my truck is built it'll be on a 5.5/7 drop, spring/disc drop in front with spring/block/notch in the back. I had a 3/5 drop on 15s before I tore back into it, it rode on my bump stops in the back, so I had to lop half of the stops off until they were 1/4in from being flush with the bottom of the frame. I had good suspension travel, there really isnt much weight back there so it didnt bottom out unless it hit a hard pot hole. Even then it wasnt bad. I had KYB gas shocks and they are nice. If one day you ever have the bed off (if I were you) I'd just buy the CPP notch kit and throw that in.
I really liked the 3/5 I had on my truck before, rode great, and I'm sure youll like it. Plus - youre not rock crawling, so why have more than an inch of suspension travel?
"Sometimes I do serve as a good bad example. Glad to be of service." My Build Thread (1967 C10, lowered, EFI, daily truck): http://67-72chevytrucks.com/vboard/s...d.php?t=830809 |
09-13-2016, 04:50 PM | #12 |
3.5/6 with 3" body drop----15x12 6.5 bs 345/55/15's and 15x8 3.5bs 255/60/15s fronts will rub fender lip if not careful in a turn. But I have pb narrow/forward arms ordered😆
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
09-13-2016, 05:12 PM | #13 |
I am stoked on the info from everyone. Looks like I can go a 3/5 drop (3" springs front/3" springs + 2" blocks rear, cut the stop in half). Now I'm torn on running 275/60 15 all the way around or 255/60 15 front, 275/60 15 rear... It has 31 11.50 15 in rear now and they rub the bed. I do have a set of 1.5" spacers that will bring the rims out for a better offset.
