09-18-2016, 09:52 PM | #1 |
Drum to Disc brake swap
Can I take the disc brakes off a 1971 c10 5lug and put it on a 1970 c10 6lug would I just need 6lug rotors what all has to be took off to work
09-19-2016, 01:04 AM | #2 |
Re: Drum to Disc brake swap
No, the spindles are different sizes
09-19-2016, 07:53 AM | #3 |
There are some very reasonably priced disk brake kits that have all the pets you need. I think I found a 6 lug front disk conversion kit for about 500 bucks or so
09-19-2016, 08:03 AM | #4 | |
67-72 parts collector,…
BUT,... the spindles will not bolt on to your 1970 truck suspension without changing the balljoints and outer tie rods. An easier solution would be to use aftermarket 6-lug rotors on 63-70 conversion spindles. These spindles WILL bolt directly onto your 1970 truck suspension.
