09-22-2016, 08:47 PM | #1 |
Location: vancouver b.c....is the biggest place most people would know but I am actually out in the valley 45 mins away
46 gas pedal help
We are building a 1946 chevy pick up and have a gas pedal question .....What are we missing....What connects the ball to the pedal ?....we have the link pin but can't find a picture of the missing part .....any help ?
1966 Pro street build http://67-72chevytrucks.com/vboard/s...?t=448089[ 1958 LS 2 build http://67-72chevytrucks.com/vboard/s...d.php?t=527123 1966 SBFS low and go http://67-72chevytrucks.com/vboard/s....php?p=5799909 1966 SBFS street HULK http://67-72chevytrucks.com/vboard/s...=1#post5886625 Poject Low and go gets a 6.2 ltr LSA supercharged with 6 speed automatic Aluinum Radiator Dealer pm for details |
09-22-2016, 09:08 PM | #2 |
Re: 46 gas pedal help
You have the wrong end it would seem. Should be flat and have a bolt hole to go in. Should be one solid arm, not anything connected to a ball. (See attached pic)
09-22-2016, 09:16 PM | #3 |
Wow....thats nothing like we had what we had when it came in.....Thanks for that
09-22-2016, 09:21 PM | #4 |
09-22-2016, 09:42 PM | #5 |
Well we are having a problem with the springs on the carbs and stiff linkage bending the rod we made so was wondering what it had from the factory......But i searched all over and couldn't come with a picture or anything other then the pin and the pedal. Thanks again I knew someone here of the forum could help me out
09-22-2016, 09:14 PM | #6 |
A couple of pictures showing the dual carbs it also has a set of fentons....led projection head lights .....dropped straight axle....4 wheel power disc brakes
thanks
