Old 09-25-2016, 04:57 PM   #1
sberman431
69 chevy with 250 ?
Just got the truck runs ok at high speed but at low speed really have to keep foot on gas to keep it going , any ideas on how to fix this ?
Plugs are new points new cap new help please
sberman431 is offline   Reply With Quote
Old 09-25-2016, 05:04 PM   #2
Grumpy old man
Grumpy old man's Avatar
Re: 69 chevy with 250 ?
There could be a dozen reasons , Have you tried to adjust the idle screw on the carb ? ? Are you familiar with these old trucks ?
Old 09-25-2016, 05:09 PM   #3
sberman431
Im familar with the trucks just not a 250 . I tried to adjust the idle screw but did not help . I was thinking might need a carb rebuild . It was from a high elevation and im at close to sea level not sure if that would make a big difference . Looking to get a manual now
Old 09-25-2016, 05:40 PM   #4
Jarvis-69 GMC 1500CK
i have the haynes book, is it stock carb?
Jarvis-69 GMC 1500CK is offline   Reply With Quote
Old 09-25-2016, 06:00 PM   #5
sberman431
Yes it is the stock monojet
Old 09-25-2016, 06:09 PM   #6
Does it idle well after start but die after you throttle? could be too strong throttle spring.
with truck idling back what you think is idle screw all way in it should then idle crazy high.
ill look in my book to see what carb # it is. from there you can look up manual.
in my book its rochester "mv"
http://www.carburetor-parts.com/Roch...al_ep_352.html
idle speed spec is 480-500
Old 09-25-2016, 06:13 PM   #7
sberman431
It will start fine then when i put foot on gas it dies out and then once im moving faster is ok
Old 09-25-2016, 06:22 PM   #8
LockDoc
The Older Generation
LockDoc's Avatar
That sounds like the accelerator pump is not working.
LockDoc
Leon
Old 09-25-2016, 06:24 PM   #9
sberman431
Lockdoc acc pump on carb?
Old 09-25-2016, 06:28 PM   #10
LockDoc
LockDoc's Avatar
Yes, when you step on the accelerator pedal the accelerator pump squirts a shot of gas into the throttle plates to make up for the extra air entering the carb. If the accelerator pump is not working it will get too much air and not enough fuel which makes it stall out....
LockDoc
Leon
Old 09-25-2016, 06:19 PM   #11
Old 09-25-2016, 06:23 PM   #12
sberman431
Thanks mine is earlier then that ill look for a manual later
Old 09-25-2016, 06:44 PM   #13
geezer#99
geezer#99's Avatar
Sounds like too much air from a vacuum leak!
Old 09-25-2016, 06:56 PM   #14
sberman431
Ok good a couple things i can check
Old 09-25-2016, 06:57 PM   #15
prodjay10
Use some propane to check for vacuum leaks. And rebuild the carburetor. Mine had a similar issue and it had a couple vacuum leaks. One around the intake manifold and the other at the base of the carburetor.
I ordered my rebuild kit from mikes carburetor and they have been really helpful. I like the brass float the kit came with.
prodjay10 is offline   Reply With Quote
Old 09-25-2016, 07:46 PM   #16
sberman431
Well it was a vacuum found a bad rubber cap on one of the nipples replaced it good to go
Thanks for the help
