Old 09-29-2016, 07:45 PM   #1
1971c10La
Truck bed help?
How can I tell if this is the bed that came with my truck it's a 1970 gmc with side marker lights on the front but not the bed didn't all trucks have side lights since 1969 might b wrong any help plz trying to do d out if I have a 1967 short bed
1971c10La is offline   Reply With Quote
Old 09-29-2016, 07:57 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: Truck bed help?
Either someone has filled the marker light holes or it is a '67 bed. You should be able to see from underneath if someone has filled them....
LockDoc
Leon
Old 09-29-2016, 10:32 PM   #3
saxart
saxart's Avatar
Re: Truck bed help?
LockDoc
Doesn't shortening the bed also make the rear marker lights go bye-bye? Maybe it's a shortened long bed?
Meet "Old Roy": http://67-72chevytrucks.com/vboard/s...d.php?t=707801
saxart is offline   Reply With Quote
Old 09-29-2016, 11:05 PM   #4
71swb4x4
71swb4x4's Avatar
Re: Truck bed help?
Depending on how you shorten it. But then you also have the middle stake pocket to make disappear, so the OP can look for signs of that too.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 09-29-2016, 11:34 PM   #5
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Re: Truck bed help?
If the rear wheel well rim is the same front and back then it's a short bed. If the front rim curves forward at the bottom then it's a long bed. Not sure if that applies to all years 67-72.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
