1967 k-10
I want to convert my K-10 to power steering and retain to original front axle. any parts lists, help and advice is most welcomed. Also adding A/C and power brakes at this time.
Thanks! |
Wide n'Low
![]() Join Date: Jan 2007
Re: 1967 k-10
I'll eventually be doing the same to mine, I did some research last year, let me see if I can track down the parts and associated numbers..
Trippin Hazard.. 67 swb, Gold Member.. 68 Suburban Air Force Retired |
Re: 1967 k-10
Thanks Twisted78SS,
I have a Saginaw pump mounted on the engine. Got that part off the upgrade covered. |
Re: 1967 k-10
Got the alternator and P/S all aligned up. A/C compressor next. I haven't purchased any brackets or other components for the A/C yet. Can't wait to get started on it though. In the meantime, going to start removing the body from the frame.
I have found a lot of helpful information on this site. Thanks all! |
Re: 1967 k-10
I'm not positive about 4 x 4's, but have converted a 72 and 70 two wheel drives to power steering using parts from 73-79 Chevy donor trucks. All of the parts bolted up. Imagine 4 x 4's should be the same.....
Re: 1967 k-10
If you are still running the closed knuckle dana 44 ck out my build in the 60-66 section. some info you should be able to use on your 67. have fun------
1961 chevy K10 my build is------------61K10 build |
Re: 1967 k-10
Yes sir! still running the old style front diff. What you have done is GREAT! Who made that sexy bracket? Do you have a P/N for the gearbox?
Going to try and add overdrive and put the 4:11's back in. Been running 3:73's for years but still have the old sets. |
Re: 1967 k-10
you need a steering box from a 4x4 only that mounts on the outside of the frame. not a 2wd s-box. the bracket is made by captianfab on the 60-66 side. he should be here also.
Re: 1967 k-10
Thanks much!
