Does this part go on a power
drum brake set-up? (I have been working on my brakes and this forum has been a huge help but this one question I just cannot find the answer to so I found a good pic.) I bought this exact MC and put the large end of the big rubber thimble shaped boot over the end of the MC where it mates to the booster. Does it belong there?
Thank you and I apologize for not being able to find the answer. |
![]() Join Date: Sep 2007
Re: Does this part go on a power
it loooks like the boot for the firewall where the rod goes thru to attatch to the pedal
1967custom |
#3 | |
Old member
![]() Quote:
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
So it does go on the end of MC. Thank goodness!
![]() Join Date: Sep 2005
It will not be used on the power brakes only on manual brake systems
#6 | |
Old member
![]() Quote:
Yikes, ok thanks! That help explain a lot!
Master with deep hole is for manual brakes and uses the dust boot.
CPP sells a master with deep hole and provide a spacer plug so that it can be used with a power booster. If you know what you are doing and have a lathe, you can make your own spacer. If not, return it for the correct master. No matter what you do, the adjustable pin in the booster must be checked and adjusted to fit the master.
'67 GMC 2500, 292, 4spd, AC |
Nice ~ does anyone sell this tool ? .
I didn't see it @ Harbor Freight and spent far too long fooling with assorted adjustments .
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
Well I removed it and wow-what a difference, thank you all VERY much!
