10-07-2016, 09:44 PM | #1 |
Air compressor: rebuild or replace pump?
I have an upright Craftsman air compressor that doesn't build pressure as quickly as it used to. Thought it was the filter but swapping in a new one didn't change the recovery time. I used to be able to run my whiz tool (die grinder) or my sandblaster and it would run, build up pressure and shut off. Now the sandblaster and the whiz tool lose power and the compressor runs constantly and doesn't catch up.
I can get a complete brand new pump for about $190 or a ring and seal kit for about $90. It just doesn't seem right to spend the extra 100 bucks but considering I would get the whole pump............. Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) Last edited by pwdcougar; 10-07-2016 at 09:52 PM. Reason: spelled something wrong! |
10-07-2016, 10:59 PM | #2 |
Re: Air compressor: rebuild or replace pump?
picture of compressor, please
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT |
10-07-2016, 11:12 PM | #3 |
Not much to see I had to mount it facing the wall for clearance. It is a 60 gallon Craftsman, oil lubricated, single stage with a 3.7hp motor. 10 cfm @ 90psi. Two cylinders. Probably about 5 years old. Research says it is a Sanborn 165
Paul
"You know that little thing in your head that keeps you from saying things you shouldn't? Yeah well, I don't have one of those" 1969 Mercury Cougar Standard 4 speed 1969 Mercury Cougar XR7 convertible 1970 4WD Chevrolet Suburban 1997 4WD Chevrolet Silverado Extended Cab Short Bed (purchased new January 1997) |
10-08-2016, 12:03 AM | #4 |
Its what i wanted to see. Looks to be a aluminum head chinese pump
can get a replacement at harbor freight http://www.harborfreight.com/145-psi...ump-67697.html A quality replacement pump may cost a little more http://www.ebay.com/itm/Kellogg-Amer...4AAOSwoydWp9pR
10-08-2016, 02:00 PM | #5 | |
Wow that's quite a difference! Thanks Warren!
10-20-2016, 08:42 PM | #6 | |
Hey Warren Looks like I won't be able to score the one from work next year after all. They took the conversion out of the budget. I did a search on Ebay for 3hp pumps and came up with this one. http://www.ebay.com/itm/EMAX-3-HP-Si...8AAOSwSclXK6WM Is this one better than the Harbor Freight pump? Paul
10-07-2016, 11:08 PM | #7 |
Model number?
I'd say why not rebuild since chances are the new pump is from Asia. My opinion after 4 compressors is if it isn't an 80 gallon Quincy or Saylor-Beall, why bother. |
10-08-2016, 05:05 PM | #8 |
i have a 18 yr old craftsman 10 cfm @90psi with a 7 hp motor that i never turn off unless i go on vacation
my neighbor has the same compressor as you have with the 3.7 hp motor and about the same age it has the same problem where it won't build pressure i think craftsman just used a cheap pump on them i'd buy a new pump before wasting $90 on rebuilding a cheap pump either way you'll still have a cheap pump
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
10-08-2016, 05:52 PM | #9 | |
Think I'll spring for the new Harbor Fright pump that Warren provided a link for. At work we have a couple nice older IR compressors that run what's left of our pneumatic thermostat system. Next summer they are scheduled to be removed and the system upgraded to electric controls. I'll pick one of them up and rebuild it. The HF pump should last a year! Thanks again guys Paul
10-20-2016, 08:51 PM | #10 |
10-21-2016, 01:11 AM | #11 |
Something like this:
http://www.ebay.com/itm/Champion-VP1...gAAOSwOdpX1wpK or this http://www.ebay.com/itm/Schulz-Singl...0AAOSwx~JWFA~V
1969 307, t350 1950 Chevy Wagon 1978 Big 10 1967 C10, 250,3-OTT Last edited by Warrens69GMC; 10-21-2016 at 01:24 AM. |
10-21-2016, 08:48 PM | #12 | |
Paul
10-21-2016, 09:27 PM | #13 |
They seem decent enough. I linked to more widely known quality compressors.
10-21-2016, 09:34 PM | #14 | |
Thanks again Warren
10-21-2016, 09:55 PM | #15 | |
Sorry for being a pain. I've been comparing the photos in both of your links and I believe they are the same brand of pump. The Champion pump shows a picture with a Shultz data plate! Paul
10-23-2016, 02:20 PM | #16 | |
Made an offer on the Champion pump and will get it for $200 shipped. Thanks again. Paul
10-23-2016, 11:12 PM | #17 |
Awesome!! should last for many years!!
10-27-2016, 08:38 PM | #18 |
The new pump came in and now I've got another problem. The original chinese pump has two things going into the pump head. One is the the supply to the tank and the other goes into the pressure shut off. The new pump doesn't have the tapped fitting for the pressure switch line. Any ideas on how to plumb this?
Thanks Paul
11-04-2016, 10:54 PM | #19 | |
The 1/4" line is probably for the unloader valve, it empties the pressurized air out of the cylinders/line so the compressor starts easily and doesn't damage the motor. |
10-28-2016, 07:57 AM | #20 |
My champion pumps at work the pressure cut off is pumbled to the tank
10-28-2016, 12:49 PM | #21 |
Thanks David. I'm not sure the tank wall is going to be thick enough to drill and tap though. I'll have to look and see if there is a good location to do it.
Paul
10-28-2016, 03:07 PM | #22 |
Registered Truck Offender
Why not just use a T fitting at the tank and read PSI off the pressure line from the compressor?????
Still playin with trucks, even at my age! When you're dead, it's only a problem for the people around you, because you don't know you're dead. .....It's kinda the same when your STUPID. I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral. |
10-28-2016, 06:01 PM | #23 | |
Thanks Marv Paul
10-29-2016, 12:56 AM | #24 |
Some of the compressors use a t fitting at the inlet
http://2.bp.blogspot.com/-ynDHNO_Klr...422_094716.jpg
10-28-2016, 04:33 PM | #25 |
yea you really dont wanna drill the tank ours are made that way with a place welded in
