![]() Join Date: Feb 2003
Headlights on 83 1 ton not working
All of the lights on my 83 are working except the headlights. If there is a thread on the board, I can't seem to find it. Could someone help me out or possibly tell me where to start to find the problem? Not much of an electrician and not a lot of patience.
Thanks. |
Re: Headlights on 83 1 ton not working
I had something like that happen on my 87, just one light wouldn't work. Ensure that it isn't a bad bulb or fuse first. Un-crimp the bayonet plug that attaches to the headlight, then touch the wire to a test light. (The kind that lights up when you have a complete circuit). If you get a light, then just clean up the bayonet plug, and crimp or solder the wire back on. If you still have no lights, check your ground. Hope this helps.
Thanks.
![]() ![]() Join Date: May 2015
Could possibly be the switch is bad..I had one on my 86 go bad years ago..do the park lights work ?
Yes, park lights work. Just seems to be the headlights that aren't working.
Had similar thing on my 83, turned out it was dimmer switch.
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" ![]() |
