10-08-2003, 09:30 PM | #1 |
I hate trannys
motor getting to hot then not starting
Today I was with a friend picking up his dads dry cleaning, and when we were waiting in the drive through my temp went from 190 to about 215 in about 2 mins. I knew it was getting to hot so I shut it off. When I went to start it again it wouldnt turn over it barley started to, sounded like my battery was dead. I have heard of starters getting to hot then not working could this be the cause? or would it be because I have an electric f uel pump and 2 electric fans that are not on switches? or a combonation? Also while im on the topic how hot is too hot for a motor to run?
70 SWB 481 ci, TH-400, Edlebrok Victor Jr. intake, Holley street avenger 770, Dynomax ceramic coated headers. Dual flowmasters. and only 3516134 more little things to do. |
10-08-2003, 09:33 PM | #2 |
Firefighter
How's the coolant level? Is it full or really low?
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA |
10-08-2003, 09:37 PM | #3 |
I hate trannys
It was too hot for me to check...I will try to go start it again in a few mins, good thing it was only a few blocks away.
10-08-2003, 10:04 PM | #4 |
I hate trannys
Just tried again, wouldnt start. Looks like im gonna have to try and jump it.
10-08-2003, 10:40 PM | #5 |
there are several things to check first being the condition of the battery.
second heat can cause more strain on the starter but usually that is a condition where the solenoid wont kick in at all, just a single click sound. Third....that symptom is usually found to be too much initial advance, with the heat factor thrown I would check timing first. |
