Old 10-14-2016, 10:54 AM   #1
wwdd77
notch question
quick back ground. 65 c10, dropping this thing down as far as i can go with a static drop.
Front crossmember has been pancaked 1.5 inches, 2.5 drop sprindles, moved forward 1", LCA moved forward .75 inches, and added a t-bird Rack and Pinion.
I setting up the rear now. the rockers are about 6-7 inches off the ground and level. I'm putting in a 9C1 Rear with its triangulated 4 link and addind coilovers. i need a notch before i can set up the trailing arms.
I don't think i can use a standard bolt in c-notch since it won't have enough travel. I was going to buy a 8" notch weld in kit (for laying frame). the question i have is, can i just not install it a full height and have a 6" notch? i'm just trying to keep the hump in the bed a small as i can since i don't really want to bag it.
Also, aside from the PBfab 300-600 notch kits out there, what else is a good option?
Thanks!
wwdd77 is offline   Reply With Quote
Old 10-14-2016, 11:32 AM   #2
The Rocknrod
Moderator
The Rocknrod's Avatar
Re: notch question
I say go for it. What are they gonna do, cut your hair and send you to sea?
Old 10-14-2016, 11:50 AM   #3
wwdd77
Re: notch question
i was more concerned since i was lowering the notch on frame it would mount in a more narrow location apart from each other on the frame rail. there is a bend in the frame (inward), i wasn't sure how much straight section was available (on each side of the notch). To make the notch less tall, will would also make it less wide.
G
Old 10-16-2016, 05:03 PM   #4
gringoloco
A guy with a truck
gringoloco's Avatar
Re: notch question
Yes, you can cut the notches down. Check out CAchassisworks or thorbros for a good/cheaper 63-72 notch.
-Chris
Instagram _elgringoloco_
'70 Short-Wide How to: Ruin a perfectly good C10
‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd
'72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD)
'72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD)
'05 Yukon Daily Driven (not so stock) Yukon (SOLD)
‘07 Yukon Denali (daily)
Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy
gringoloco is offline   Reply With Quote
Old 10-16-2016, 05:11 PM   #5
wwdd77
Re: notch question
Thanks Gringoloco for the helpful response.
I ordered one up from thorbros this morning, so I am happy to hear they were recommended.
