10-17-2016, 10:40 PM | #1 |
Drilling extra holes in frame
Hello,
Any dangers, rules, or pointers I should keep in mind when drilling holes into any part of the frame? I don't want to weaken it or harm the structual intergrity in any way. I don't like the idea of drilling into it at all, but I need to place some clamps in in order to run some cable. Now under the cab area above the spining shaft I made some "L" shaped sheetmetal pieces and used 3M attachment tape to attach them. I drilled into the pieces and not the cab, but I need to run heavy cabling along the inside of the left frame rail. Thank you. Sincerely, IM |
10-18-2016, 12:05 AM | #2 |
Re: Drilling extra holes in frame
Drill away!
You won't hurt anything. Back in the early sixties there were Pontiac's with a multitude of holes in the frame. Purposefully done to shave off weight for racing. They called them 'Swiss Cheese' Pontiac's!! Check out this frame. http://www.onallcylinders.com/2015/0...eese-catalina/ |
10-18-2016, 02:24 AM | #3 |
I wouldn't drill any holes near where these frames crack such as steering box and shock mounts.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 |
10-18-2016, 02:53 AM | #4 |
Depends the size hole and where your gonna put it.
10-18-2016, 03:59 AM | #5 |
10-18-2016, 09:14 PM | #6 |
Tags |
danger, drill, frame, safety |
