Drop Shock suggestions for 1962 C10
New to the forums. Did a ton of digging, hoping someone here can help.
1962 C10, Long bed, T-bars turned up, 2" blocks in the rear. I need some shocks. Thanks!! |
It's Better With Nitro
Re: Drop Shock suggestions for 1962 C10
What's your budget for the shocks?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
I ran Pro Comp before and after bags. Toxic shocks rear now still a pro comp with different sticker. KYB up front. Amazingly KYB is available at O'Riely in stock. You need to measure for proper hieght. Make sure unload weight is middle of full open/close 3" minimum.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
