10-22-2016, 12:57 PM | #1 |
Turn signal indicator lights up when headlights on
I don't drive a lot at night but yesterday evening I did and noticed my right turn indicator in the dash was glowing slightly, I checked all my lights and they're all working properly. I checked all the bulbs in the back of dash, couldn't find anything wrong with wires or bulbs. Anyone have an idea what would cause this?
http://smg.photobucket.com/albums/v655/aaronhero/ |
10-22-2016, 01:25 PM | #2 | |
Re: Turn signal indicator lights up when headlights on
10-22-2016, 01:33 PM | #3 |
Sounds like you have a bad earth connection somewhere, most likely on the rear lights.
10-22-2016, 01:38 PM | #4 |
20' Daredevil (Ret)
I'm also thinking a poor ground connection.... my guess was maybe a side marker light.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
10-22-2016, 01:58 PM | #5 |
You have had a few ideas from here so I would start with GROUNDS and go from there.
10-22-2016, 02:40 PM | #6 |
Your electrons have gone renegade seeking the path of least resistance. These can be difficult problems to solve. I remember my old man fixing a high beam indicator that wouldn't shut off by "Reaching under the dash and pinching that bulb with some pliers.". You might try pulling fuses one at a time to see if the problem goes away. This could point to the area with the faulty ground. Good luck. I just went through this on my S-10. By pulling fuses and staring at the wiring schematic for hours I figured it out.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
10-22-2016, 03:33 PM | #7 |
Does it stop glowing if you turn the dash lights off? If so the cardboard tube that isolates the blinker bulb might have come apart letting in light from the other instruments making it glow.
My Patinia'd 69 69-http://67-72chevytrucks.com/vboard/showthread.php?t=517537 My RHD 68 http://67-72chevytrucks.com/vboard/s...d.php?t=594928 |
10-22-2016, 05:00 PM | #8 | |
Posted via Mobile Device |
10-22-2016, 03:54 PM | #9 |
2, 6 & 7 sound right to me, the novice. If it were me, I'd check the wires under the hood and dash, then run with post 7, then 6, then perhaps your problem is post 2.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
02-01-2017, 11:05 PM | #10 |
Still having issues with the indicator light on my dash and tonight I noticed the high beam on the passenger side is out, the same side as the indicator light that's glowing. (This is a GMC so it has four headlights) could this be why my indicator is glowing? Do they glow when a headlight goes out? I'll be replacing the high beams tomorrow but I was curious to know if this could be my problem?
02-02-2017, 12:38 AM | #11 |
I recently installed missing park lights on my firebird and I have the exact issue. Mine is not light spill, but the right turn indicator on the dash is lit When I turn on the lights. When I drive, it goes off sometimes when I hit a bump. I'm guessing ground or exposed wiring somewhere. If I find the answer, I'll post on here.
02-02-2017, 07:36 AM | #12 |
Went through the same problem on my 71. Turns out it was the grounds adjacent to the headlight sockets in the wiring harness that attach the radiator core support. Took them off and clean off the crud/paint and reattached. No more glowing light.
11-15-2017, 05:35 PM | #13 | |
Who Changed This?
11-15-2017, 05:40 PM | #14 |
I have the same problem as the OP. the filament in my dash turn signal light is normal. ive tried 3 different bulbs. I think it might be a grounding issue somewhere, just not sure how to track it down.
1970 Chevy C-10 Stepside My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167 |
02-02-2017, 09:44 AM | #15 | |
Old member
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-02-2017, 10:38 AM | #16 |
I just went through this on my build, the bumper mounted lights have 2 wires, one for marker, one for turn, the ground is chassis through the housing. If you lose this ground the turn indicators will dimly light when the marker lights are on. Also if the bulbs are bad it will cause the same problem.
02-02-2017, 06:29 PM | #17 |
I too had this problem on my '72. Solved by running a separate ground from blinker housing to bumper bracket/frame.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor. |
11-15-2017, 04:11 PM | #18 | |
Also, OP: solve your issue yet?
