So i found stuff.
So i finally decided to try reading the SPID sheet, and found out that my truck is a 350 v8 truck with a turbo 400 trans, power brakes, ac, power steering, was white, had a blue interior, and this is what it has right now. but its on a 73-87 frame, but it looks like the original motor/ transmission. but my truck has been restored before, but i think it may be numbers matching.
1967 GMC C25 305 V6 1969 K20 CST 1994 k1500, Oldredz71(ext shorty 4x4 6 in lift) 1998 S10ZR2 2001 Silverado 2500hd 8.1L 2003 Silverado 2500hd Crew cab |
Re: So i found stuff.
Kinda hard to be 'numbers matching' if the frame is different.
THere are vin numbers on the frame you know. |
#3 | |
What's the casting codes, date codes and suffix codes on your motor?
Il look at that tonight if i remember, its lifted so doing anything in the engine bay is a PIA and makes me become a human pretzel.
How can you tell from the SPID sheet that the trans is a TH400? My SPID just lists M49 Turbo-Hydramatic, and it turns out to be a TH-350.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
Turbo 400 is rpo code m40.
hmmm il check when i get home, but i know its a 400 trans.
All about them K’s
![]() Join Date: Jun 2014
your truck was born 2 wheel drive and converted to 4x4 am I correct? The 2 wheel 400 and 4 wheel 400 are different and short of a divorced transfer case a 2 wheel trans won't work in a 4x4. So if your truck is converted to 4x4 than that means it's not the original trans... Also no 67-72 4x4 auto ever came from the factory with a th400, all 4x4 autos were th350.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
#10 | |
![]() Join Date: Mar 2003
The 400 2wd had the same output shaft as the 4x4 for the 205 t-case, and can be easily swapped with just the adapter. 203 t-case took a shorter output, and the 241/208 combo had a different length also |
#11 | |
The out is 32 spline but is longer than a 4wd shaft.the 400/205 is very hard to find but I do have a few laying around but have sold hundreds over the years to ORD. |
Had a brain fart and had t350 on the brain sooo the 400 short 2wd is the same.lenght
Oops 😅😅 |
#13 | |
http://67-72chevytrucks.com/vboard/s...d.php?t=637778 |
Did the 73-87s come with a th400?
