10-25-2016, 01:22 PM | #1 |
C10 Collector
Bed Assembly question - rear tack welds
When you guys are reassembling beds do you tack weld the rear crossmember back in like from the factory?
I took mine apart and had all the bodywork done when it got flooded. I sandblasted it and started over. It is in epoxy primer right now and I am finishing body work again. I was going to assemble the bed prior to paint but was wondering how others handled those tack welds.
///Ryan 1972 Chevy C-10-Bagged, Blown LT1, 700r4, Suicide Doors 1967 GMC- SC & Cam'd 4.8, built 4l80, 3200 stall, posi, 4.10 1967 Chevy LWB- 454 and patina 1971 Blazer - Rusty 1968 Crewcab project |
10-25-2016, 01:27 PM | #2 |
Re: Bed Assembly question - rear tack welds
I would tack weld them like the factory. That way you will not get any movement of the bedsides that could cause your tailgate not to close correctly.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
10-25-2016, 02:55 PM | #3 |
C10 Collector
Thats what I was thinking. Now I need to come up with a way to transport an assembled bed with no floor.
Maybe I will make a bed cart and bolt temporary crossmembers up or something to attach to the inner bedsides.
10-25-2016, 03:04 PM | #4 |
Why not just borrow a welder?
10-25-2016, 03:05 PM | #5 |
C10 Collector
I have plenty of welders but the paint shop is an hour away. Got to weld it before paint but put floor in after paint
10-29-2016, 07:02 AM | #6 |
Been thinking of the same thing also. how about drilling a couple more holes to fit tightly on a 5/16 bolt after alignment has been done?
10-29-2016, 08:51 AM | #7 |
I never welded mine after taking it apart and putting it back together, and it has never moved. Just made sure all six bolts on each side are really tight. If you plan to haul heavy loads against the bed sides, a weld might be needed.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
