Old 10-27-2016, 08:32 PM   #1
Ultanium
High RPM on highway
Been working on my 69 C20 Panel truck all week, and have made lots of progress, to the point where I can drive it pretty much anywhere. The PO had put the two piece driveshaft in wrong, leaving the carrier to handle the flex of the rear axle. The truck has a 350 crate engine, and 700R4. Once we got the engine tuned up, and took it out for a test drive, the 350 was spinning at 3400 RPM at 60 MPH. I thought for sure that the 700R4 wasn't going into 4th, but it was. The truck has a Dana rear, and we are guessing 4.56 gears. I hate to lose the Dana, but I think I need to swap something a little more highway friendly, if I'm going to use this truck for cruising. I am thinking a 3.73 gear will bring it down, and maybe a 10 bolt or 12 bolt, with posi wIll be just fine. Will only be towing a light trailer with this panel, nothing heavy. What rears will direct swap without too much hassle? Is the Dana worth anything?
Tom
Ultanium is offline   Reply With Quote
Old 10-27-2016, 08:51 PM   #2
Steeveedee
Who Changed This?
Steeveedee's Avatar
Re: High RPM on highway
Other Dana axles are out there. I have a Dana 60 in my truck, with a 3.55 ratio. It's a leaf spring rear, as I have a Custom Camper, but you ought to be to find what you need. The 700 has a real digger first gear to get you off the line, but you probably don't want to go higher than 3.55 or 3.73, if you plan to tow (you'll possibly get detonation in OD if you go to a tighter ratio). I also wouldn't recommend using the lockup feature when towing, for that matter.
~Steven
Simi Valley, CA
Old 10-27-2016, 09:25 PM   #3
TwoFiftyShifter
3400 at 60 in a 1:1 would be 4.57 gears. When OD engages it would lower your rpms by 30% I.E to 2400.
Something is up alright.
1982 K10 SWB
1987 V20 - Sold - Doh!
TwoFiftyShifter is offline   Reply With Quote
Old 10-27-2016, 09:53 PM   #4
70STOVEBOLT
70STOVEBOLT's Avatar
Converter probably not locking up.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 10-27-2016, 09:59 PM   #5
davepl
davepl's Avatar
BY 3000rpm the centrifugal force locking up the converter is pretty tight, unless it's some wild aftermarket converter.
I'm thinking you're incorrect in your assumption that you're seeing fourth gear. I run 4.10s and with the 4L85E I put along around 2K on the highway (actually just a bit above that) at 60+ I think.
Really sounds like you're in third. I've been wrong before though!
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 10-27-2016, 10:02 PM   #6
trac209
Id concur with above,doesn't sound like it's going into fourth or you have some real steep gears. What's your tire size ?
trac209 is offline   Reply With Quote
Old 10-27-2016, 10:22 PM   #7
Ultanium
It definitely is in 4th. In first gear, I can get up to maybe 8mph, and the 350 is screaming, I swear I think I can lift the wheels from a standstill. The truck has a megashifter, so I walked it through all 4. There is no lockup on the trans, I will look for the plug when I put it back up on the rack. I just think with the low first gear of the 700R4 and the tall gears, everything is mismatched for highway running. I'll try to get some pics and video this weekend.
Tom
Old 10-28-2016, 11:43 AM   #8
Ultanium
https://youtu.be/RUJgozmedIM
Old 10-28-2016, 12:18 PM   #9
RustyBucket
RustyBucket's Avatar
I watched your video... don't see how the numbers are possible. 700r4 has a .70 O.D. ratio. On a 30" tall tire 3500 rpm in O.D. at 60mph works out to a 7.44 rear gear ratio. Is there a setting on your digital tach. that could account for this? Maybe a bad converter. I wouldn't go changing rear gear ratios til I figured it out. Curious to see what it is.... Like to see pictures of the truck too.
PS.. the 30" tire is just an average... don't see your tire size in your post
Dad always said, "Son, WISH IN ONE HAND, and ......."
Current toy trucks:
'71 GMC 1500 SUPER CUSTOM short/step, orig. dk. blue, 350/700r, ps,pb, A/C
'72 Blazer 2wd, ochre & white, 454, tremecTKO 500 5spd. ps, pb, A/C, tilt
Last 10yrs of hobby vehicles, had a FEW more in the 50yrs. before these:
'66 Plymouth Belvedere City of Miami cop car clone.
'70 Nova 406"sb, 13.5-1, solid roller, Brodix, p.glide/t.brake, back halved, 9" Ford, spool 4.88, cage,ladder bar/coilover, 10.5 tire....... SOLD!!
'67 C10 short/step side mount spare -- SOLD!!
'72 Jimmy 2wd, 350/350, ps, pb, fun driver, lots of bondo & a shiny red paint job..... SOLD!!
'69 Nova 350, 4spd, A/C, ps, p.b, ...SOLD!!
RustyBucket is offline   Reply With Quote
Old 10-28-2016, 12:34 PM   #10
outfield
Everyone is spot on, your RPM's are too high to be in overdrive. Unless you have 5:38 gears...
Here is the RPM chart for 4.56 gears and 29 inch tires:
4.56 gears
Tire Dia. 29 inch
45 mph 2377
50 mph 2642
55 mph 2906
60 mph 3170
65 mph 3434
outfield is offline   Reply With Quote
Old 10-28-2016, 12:36 PM   #11
davepl
davepl's Avatar
I watched the video, and it does seem like you go through four discrete gears. But in the video it doesn't sound quite like the engine matches the tach, almost. You don't have a Pertronix Ignitor module that could be throwing off the tach, do you?
I'd almost want to verify that the tach is right. If your multimeter has a Hz function or if you have a spare tach, I'd verify it neutral at 4000 and see.
Or maybe you have 5.13s in there!
Old 10-28-2016, 07:28 PM   #12
Ultanium
Tires are 265/70R16, plain old HEI with tach lead going to the Intellitronix cluster. I will make sure the cluster is set correctly this weekend. https://youtu.be/cpGzweo539k
Old 10-28-2016, 01:43 PM   #13
trac209
Without verification of gear ratio we really can't be of much help. Jack up the diff and check how many times drive shafts rotates to one rotation on the tires. If you have an open diff leave one tire on the ground to check.
Old 10-28-2016, 03:05 PM   #14
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yep, gotta verify a couple things.
Determine the gear ratio, even if it means opening the diff and counting teeth.
Compare your tach reading to a known accurate tach. It could be reading too high.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 10-28-2016, 03:25 PM   #15
RichardJ
I think the tach is off, also.
My Dana had 4.56 gears. I found a Dodge pickup in the wrecking yard with 3.54 / Posi and swapped carrier and pinion. You have to check if the axle splines are the same and change the yoke for the bigger u-joint that GM uses.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 10-28-2016, 03:38 PM   #16
BILT4ME
Is the tach set to a 6 cylinder instead of an 8 cylinder? The idle does NOT sound like 800 RPM. The 60 MPH at 4000 RPM shown does not SOUND like 4000 RPM. If it is set to 6 cyl it would be reading 25% higher. In other words, your idle is 600 RPM and the top end is 3000 RPM.
JMHO.
1970 GMC K2500
Dis-use is harder on a car than mis-use.
BILT4ME is offline   Reply With Quote
Old 10-28-2016, 07:32 PM   #17
davepl
davepl's Avatar
That tach defaults to 8 cylinder mode. You cut the blue loop for 4-cylinder, the orange loop for 6-cylinder. Be worth checking to make sure those loops of wire are still intact. If they've been cut, removed, or damaged your tach goes into 4/6 cyl mode.
Old 10-29-2016, 12:19 AM   #18
Ultanium
Got it, thanks man. I will pull it out and verify everything this weekend.
Tom
Old 10-29-2016, 09:38 AM   #19
Jrainman
Jrainman's Avatar
I have to agree with others about that tach not registering the correct RPM , I drive my truck every single day about 200 miles round trip to work mostly highway, and I know what 2000, 2500, 3000 rpm sounds like , from going by what I here in your video that Tach is way off . I would install another tach to check things out . I run a 350/th400/ 3.08
Jrainman is offline   Reply With Quote
Old 10-30-2016, 01:23 AM   #20
Sounds right, reads wrong. C/20s have short or deep gears, not tall. Tall as in long legs. Like Bonneville racers run super tall gears
Old 10-30-2016, 09:33 PM   #21
schwoch1
Local Detroit diesel nut!
schwoch1's Avatar
Have you verified the speedo reading with a GPS of some sort? 4000 RPM at 63 you would have to have a 20" tall tire or at least a 5.xx:1 gear in it!!!
Mike
Nothing cool anymore, I am old and boring....
schwoch1 is offline   Reply With Quote
Old 11-03-2016, 11:50 AM   #22
Ultanium
Hey gang, ya'll were totally right. I pulled the cluster and mine has dip switches, not wire loops. The dip switches in the manual are supposed to be for ohm adjustments, for different fuel sending units. All is well now, 2550 RPM @ 55 MPH. This weekend, I'm going to check and see if this has a lockup converter too. Thanks everyone!
Tj
Old 11-03-2016, 01:05 PM   #23
LongBox
Good to hear that the problem is not there anymore!
Rick
-69 GMC 910 Long Box, 350
-98 Chev Silverado 1500, 350 Vortec 4L60e
-08 Mustang GT Convertible
LongBox is offline   Reply With Quote
Old 11-03-2016, 01:25 PM   #24
67ChevyRedneck
67ChevyRedneck's Avatar
That's great you got the tach figured out!
You still have a lot of gear out back if you're turning 2550 @ 55mph.
MY 350/700R/3.73, 28" tall tire spins 2400 RPM at 75 MPH.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-03-2016, 04:08 PM   #25
RustyBucket
http://www.wallaceracing.com/calc-rgr.php
Have you checked your speedometer reading with a GPS? With a .70 overdrive ratio in the 700R4, using a 31.5 tall 265/70R16 tire, 2550 rpm, & 55mph the numbers work out to a 6.21 rear gear ratio. Sounds like something's still wrong in the figures 'cause 6.21 sounds way too steep to me.
Current toy trucks:
