Old 10-31-2016, 03:43 PM   #1
7tee
7tee's Avatar
Transmission output shaft centering...
How critical is it to have the output shaft centered to frame? After measureing I found that mine is 5/16" off center to the left going towards the left rear. With the pinion being offset to the right of center I was wondering about the lateral angle of the driveshaft...thanks Ed
1970 C/10 350/T5 SWB stepper...
1979 Corvette 350/Auto T-top...
2010 Acura RL...
2015 2500HD Z-71 Silverado...
7tee is offline   Reply With Quote
Old 10-31-2016, 03:57 PM   #2
cdowns
cdowns's Avatar
Re: Transmission output shaft centering...
not really critical at all
Old 10-31-2016, 04:03 PM   #3
7tee
7tee's Avatar
I'm still searching for anything out of whack that could be causing this clutch chatter or drive-line shutter, thanks for you response...
2010 Acura RL...
Old 10-31-2016, 05:03 PM   #4
geezer#99
geezer#99's Avatar
Maybe something here will help.
http://www.drivetrain.com/parts_cata..._problems.html
Old 10-31-2016, 05:21 PM   #5
7tee
7tee's Avatar
I had read that the pinion was offset to the right approx. 3/4" and being that the tranny was offset to the left approx. 5/16" making this about 1" O.A. I'm still searching...
2010 Acura RL...
Old 10-31-2016, 10:40 PM   #6
LockDoc
The Older Generation
LockDoc's Avatar
U-joints should take care of that with no problem.
LockDoc
Leon
