11-02-2016, 10:29 AM | #1 |
Need help now 1971 c10 won't start
My truck is a 1971 c10 I was driving it this morning and I was running fine and all of a sudden cut off and now attempts to start has fuel but will not run also my lights are very dim when I attempt to start but don't think it is the battery please help
Brysen and his trucks 1971 Custom/10 (the big c10) 1970 C/10 (the gold truck) |
11-02-2016, 11:08 AM | #2 |
Re: Need help now 1971 c10 won't start
start by checking the small wire going from the + battery terminal to the insulated stand off on the passenger fender. a quick check...
Thanks, Joe.. 1969 C/10, 348 C.I., 3X2 bbl. V8, 2004r , LWB. |
11-02-2016, 05:49 PM | #3 |
Its a Truck Thing......
HEI or Points?
Need to know.... Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
11-02-2016, 05:53 PM | #4 |
Do you have a voltmeter, or a multitester? If so, measure the voltage at the coil. You should have 9 volts or higher there.
If you do, the problem is either the coil, the points, the condenser, the cap, or the rotor. If you do not, start with the basics. Clean battery terminals thoroughly. Check the small wire as mentioned by hamjet. If those are OK, it begins to look like the ignition switch. Quick check for that is to run a wire from the positive battery terminal to the coil (connect to the terminal that does NOT go to the distributor. If you have HEI, I cannot help, as I have no experience.
Rick -69 GMC 910 Long Box, 350 -98 Chev Silverado 1500, 350 Vortec 4L60e -08 Mustang GT Convertible |
11-02-2016, 08:05 PM | #5 |
got to be fuel or fire
11-02-2016, 08:26 PM | #6 |
Okay power feed wire fell out of solderless conecter and hit a another terminal and fried my 12 volt relay , put on a new conecter and relay an..... is started up atnd ran fine thanks guys
