11-02-2016, 06:17 PM | #1 |
PROJECT 7DEUCE
door seal top flapper thingie?
Anyone have any good pictures of how this thing should attach?
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
11-03-2016, 12:09 AM | #2 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Re: door seal top flapper thingie?
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
11-03-2016, 12:12 AM | #3 |
11-03-2016, 09:53 AM | #4 |
2WD Jimmy
OK... I havnt seen one of those. Is it for a double wall only?
11-03-2016, 01:43 PM | #5 |
PROJECT 7DEUCE
Both single and double wall tops as far as I know
11-03-2016, 04:39 PM | #6 |
both of mine are broken at the bend and the top is missing... are they important?
'72 K5, known as 'the Fox.' |
11-03-2016, 04:59 PM | #7 |
Not important, just helps defect rain/water from coming into the cab at that corner.
11-04-2016, 09:59 AM | #8 |
Maybe I should get some new ones, because that's exactly where water comes in. And then directly onto my left knee!
11-05-2016, 02:54 PM | #9 |
Anyone know where to get these parts? Also the plastic piece (cap) just below it that mounts to the door itself?
11-05-2016, 04:41 PM | #10 |
PROJECT 7DEUCE
Gmc pauls
11-05-2016, 05:56 PM | #11 |
Yep, you have to have them if you want to keep the water out. And don't forget the RTV - see BobbyK's pics.
11-05-2016, 06:27 PM | #12 |
good pics Bobby, thank you
