67cheby
![]() Join Date: Sep 2008
Slosh Tubz now has high transmission humps!
Just wanted to let everyone know about the newest product line from Slosh Tubz we now have High Hump transmission tunnels for 60-66 and 67-72. the 60-66 are $180 shipped and 67-72 are $150 shipped.
We also have stock height widened rear tubs for 60-66 they are $400 shipped www.sloshtubz.net or call 1-479-599-9664 |
Registered Loser
Re: Slosh Tubz now has high transmission humps!
NICE! I'm sure those will help some people with their builds.
((..)) ((0)) '63 GMC lwb, 383, th350, lays frame, genuine patina. The Build Thread - http://67-72chevytrucks.com/vboard/s...d.php?t=374267 '88 Astro cargo bagged, shaved, phantom grille. *SOLD* '50 Chevy 2 door sedan awaiting attention. 2014 Silverado Ext cab, 5.3, daily driver. |
67cheby
Thanks man, i sure hope so!
![]() Join Date: Nov 2015
I will be ordering soon!
Looks like fiberglass, are there any weight savings with one of these over factory?
Yep, I'll be getting one.
nice so these are 1 pc item verses 2 like stock?if so thata the best idea ever any taxes on these?
in the market for a couple of these
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Cool addition to available parts.
67cheby
a metal cut off wheel on your grinder works nice
Thanks man |
Is there any way I can get a 60-66 hump shipped to Alaska? 99645 or 99518
perfect. I'm getting ready to cut out my rusty low hump to make room for my 5.3 - 4L60E swap.
1981 K10 (4.8 / 4L60E swap) 1982 C10 (5.3 / 4L80E swap) 1985 C20 Suburban (454 / 4L80E) |
Any ideas on low humps? I swapped my 4x4 to 2wd and think a low hump would work. I put a metal version on my 4x4 truck that has a 3"body lift. Worked out great for transfer case linkage issues with twin sticks and such.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
Which transmissions require a high hump in these trucks?
#15 |
Most. I had to raise center of mine to accommodate T5 which is not much bigger than 3 on tree. Now with Porterbuilt crossmember moving everything up. Its maditory. But you can use small shell and cut as you go. My original v8 was in rear mount. So moving motor fwd might help.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
#16 |
Yes, moving the engine forward would most likely cure my clearance issues but I wanted better weight distribution and more room at the radiator so i tucked the 5.3 as far back as I could.
I ordered my high hump yesterday....
