11-08-2016, 12:52 AM | #1 |
1970 Chevy C10 Centerlink Backwards?
Is my center link installed backwards?
I installed a CPP front disc brake conversion kit, new CPP upper and lower control arms, and new a endlink sway bar. Also installed new disc/drum master cylinder and booster from Summit for power brakes and a power steering conversion kit. Tie rods are '73-'87 style from CPP. Before and after front end alignment by a good alignment shop in Las Vegas, it still vibrates a lot when turning, especially at low speeds. Something I never had with manual brakes/steering. It also over reacts when trying to do normal steering, really annoying and borderline dangerous. Any help would be great! |
11-08-2016, 06:14 AM | #2 |
67-72 parts collector,…
Re: 1970 Chevy C10 Centerlink Backwards?
YES it's on backwards.
The inner tie rods should connect on the back side of the centerlink with the nuts on the front side. Take it off and swap it end for end.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-08-2016 at 09:13 AM. |
11-08-2016, 07:18 AM | #3 |
yep, didn't know you could but now we do. thanks for posting
Larry It is easily overlooked that what is now called vintage was once brand new. "Project 68" paypal.me/ldgrant |
11-08-2016, 09:09 AM | #4 |
Stunned. And a little worried about your alignment shop. Going out to check mine now as I too didn't know this could be done.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-08-2016, 11:38 AM | #5 | ||
"I ain't nobody, dork."
"Good alignment shop"...
They should have caught this. I bet it will drive a lot better once you swap it around correctly. Gary
11-11-2016, 07:34 PM | #6 |
Newbee
I did that once! A lonnnnnnng time ago. Steers really funky, LOL.
11-12-2016, 12:59 AM | #7 |
Yes, that did it. Swapped it end to end and placed nuts on forward side. What a difference in driving. It no longer over reacts. It takes quite some trial and error figuring out what sequence to reconnect it all. It ended up being a bit higher and closer to the cross member. lolife99, many thanks for the help!
