11-09-2016, 07:49 AM | #1 |
How do you keep your seat belt buckle from falling through the seat?
Hi, I'm not sure if anyone else has this issue, but with my 3-point seat belts, I have always had the issue of the buckle falling back through the bench seat, onto the floor.
So currently I have them held on the seat with some wire, going across the seat and hooked to the bottom (which is obviously a real eyesore). I have found that the issue usually occurs as soon as you sit down, the weight on the bottom part of the seat causes the gap to widen and the buckle easily falls through. Any suggestions/ideas will be appreciated.
1970 C10 250 3-speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=650480 |
02-25-2017, 10:18 PM | #2 |
Re: How do you keep your seat belt buckle from falling through the seat?
Any solutions? I have the same problem.
http://67-72chevytrucks.com/vboard/s...d.php?t=693490Cheyenne, AKA "Spare Change" Hack71 Build |
02-26-2017, 12:57 AM | #3 |
20' Daredevil (Ret)
My K20's seat padding is thick enough that it's a real chore getting the buckles through in the first place. No way are they gonna slip back down through there.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
02-26-2017, 09:07 AM | #4 |
Never had that problem. How much do you guys weight? Kinda serious, can't think of any other reason other than a really worn out seat? Could you just slide it to the center when you take it off? It's just where you sit that droops, right?
02-26-2017, 09:16 PM | #5 |
I have new foam and there is a small gap between the bottom and back, not much but enough that when you sit in the seat the seat belt can fall behind.
Now I'm no small guy but I'm not huge (thanks for implying special-K) it happens with light weights as well! The previous seat was just fine but the new foam and cover is slightly different plus I am no avid seat belt user so when I decide to put it on I have to try to fish them out as my seat doesn't tilt forward. looking for either seat belts that have a support cover to hold them up or another idea. Thanks
02-27-2017, 07:00 AM | #6 |
Later model g.m.'s front buckets have a plastic case/sleeve that goes over the belt..
you could use these through the seat hole on down to keep the belt end from dropping.. No one would see it.. or know.. I'm going with 2002 Trailblazer front seats, and the belts are part of the seat.. |
02-27-2017, 11:29 AM | #7 |
Same as Stocker, here - the cushions on my factory '72 bench seat are too firm to allow the aftermarket 3-point belt buckle to slip through, and I have the slimmer, GM-style buckle.
If I were you, I might just rig up some sort of "clip" that clamps on the belt and is too large to pass through the cushions. Could be pretty unobtrusive, just sitting in between the cushions...
1972 K10 Cheyenne Super | LWB, fleetside | 350/350/205 | KEEPER 1971 K10 Cheyenne | SWB, fleetside | LS Swap 5.3/4L60 | SOLD 1976 Trans Am | 400/4-spd | SOLD 1976 Trans Am | 455/4-spd | TOTALED |
02-27-2017, 12:31 PM | #8 |
Old member
This is me thinking out loud.
Take some good stick on Velcro and put it on the belt & seat where it comes through the seat at so it want slip through. It want be seen.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
02-27-2017, 01:22 PM | #9 |
Superglue a quarter-sized magnet to a safety pin and attach it to the seat under where the buckle rests. The buckle will stick to the magnet until you pull it off to use it.
02-27-2017, 01:28 PM | #10 |
My seat belt length adjustment is on the buckle side, so I just adjust it out as long as possible and tighten once buckled. Although, I believe I got the longer set of straps when I ordered the 3-point harness.
Hook'em |
02-27-2017, 01:30 PM | #11 |
They're likely not easy to find, but the bucket seat belts have a "tube" that holds the belt up alongside the bucket.
You could likely use a similar approach to ensure the belt stays stuck up through the seat gap as well. But I don't know if they're reproduced, and they're certainly not abundant used. But maybe they make them for the Blazer market?
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
02-28-2017, 02:55 AM | #12 | |
even my 88 ford f150 had them with a bench seat. |
02-28-2017, 01:41 PM | #13 |
Any links?
02-28-2017, 11:14 PM | #14 |
Found this online, has anyone tried these?
Looks like the Chevy Truck Bucket Seat seatbelt has the plastic support that holds the belt up. seatbeltsplus.com
02-28-2017, 11:23 PM | #15 |
NO links
but my 88 ford had them.. My fiero has them. my g body has them. my 1997 ford had them.. my 82/84/85/88 firebirds/t/a's my 80 t/a my years of junkyard crawls have seen them in tons of vehicles.. with bucket seats.. They keep the belt end from falling between the seat and center console.. |
02-27-2017, 05:54 PM | #16 |
I bought a couple of those nylon stretch tie downs that has the small black balls on each end and used this parachord thread to sew one through the webbing of each female. You can't really see the small ball but it is enough to keep them from going all the way through.
02-27-2017, 10:27 PM | #17 |
Some great ideas, thank you!
