10-10-2003, 12:41 PM | #1 |
86 350 Won't run
Hey thanks for the PCV info.
Fortunately down here in the South we ain’t go to worry about emissions, no smog checks here. I’ve got a 81 GMC Sierra ½ Ton, with a 1986 350, HEI ignition, Rochester Q-jet M2ME, The other morning when I tried to start it, it was running really rough, once it got warm it seemed to be ok, but the next day it got worse….and so on until it wouldn’t even stay running, during this time, it was smoking a lot when I would accelerate, (Black smoke), When I crank it If I keep pumping it, it will stay running but just barely. I have replaced all ignition components ( I was planning to do this anyway). But the problem didn’t go away, Its got to be the carb. I am thinking. Its got good compression on all 8. Since I had to pull to dist. To replace the pick-up coil I have it static timed at 6 deg. Btdc, I can’t keep it running long enough to set the timing. Any suggestions would be welcome. |
10-10-2003, 12:49 PM | #2 |
try your choke.. and about the PCV, whether you have emissions or not. you still need the PCV!
Jon 1982 Chevy Silverado 350/th350.... RETIRED 1993 Jeep XJ 2 door(Cherokee) 4wd 4.0ltr/AX-15 (5spd)/NP231 .... Oklahoma Roll Call |
10-10-2003, 12:51 PM | #3 |
carb is a M4ME not a M2ME
I made a mistake on the carb, its a M4ME
10-10-2003, 05:52 PM | #4 |
Robert Olson Transport
i had a problem like that with my 4.3 with the quadrajet now i had a PVC valve but im wondring if the carb is the problem, mine went through a rebuild which did little to help the problem cause the electric pump sensor ( not sure of its correct name) was the problem. I swapped out a different one and alls well now
hope that helps
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
10-12-2003, 12:05 AM | #5 |
Stylin
have u tried adjusting the carb? theres 2 adjustment screws at the base on both corners, you'll need to pick up an adjustment tool to adjust those
Ive been traveling for some time, with my fishin pole and my bottle of shyne. Most Girls like finished products and just dont understand what a good addiction does for you http://www.paulwall.us/ |
10-12-2003, 02:55 AM | #6 |
BAD BOW-Silverado XST
You have the same problem as chevychic. The colder weather is affecting the operation of the carb. Set your choke to stay closed longer. I have the same problem. Once my truck reaches its operating temp of 180+ is runs okay.
10-12-2003, 07:00 AM | #7 |
Filled up with gas the other day, Blazer started idling rough, bad cat converter smell. Results of finding the best gas price. Next tank all was ok.
350 Crate 10 bolt 3.73 2.5 lift 32x11.50 1904 Edelbrock http://www.oplnk.net/~spirit/K5front.jpg |
10-12-2003, 08:59 AM | #8 |
If you have a black electrical plug going into the top of that carb. then you have a "electronic" Q-Jet.
It has a mixture control soleniod under that plug and they often go out and cause the type of problems you are describing. I would fix it by putting on a Holley 650 Vac. secondary. |
