Old 11-15-2016, 11:34 AM   #1
Smitty
Smitty's Avatar
Sound Deadener and Heat Suppression
Has anyone successfully used any of the products from E-bay or Amazon that doesn't carry the price tag of Dynamat. Or have a recommendation as to what might be a good option. Truck in pieces, on the way to a restoration. Would like something economical but real satisfactory. Thanks
Smitty
'71 Short Fleetside
Spring Valley, Ca.
Smitty is offline   Reply With Quote
Old 11-15-2016, 12:39 PM   #2
chasinhiway
chasinhiway's Avatar
Re: Sound Deadener and Heat Suppression
I know there are cheaper versions but I used Dynamat extreme and am VERY pleased with the results. You can listen to the radio and carry on a conversation while running 70 mph down the road.
LOWER IT AND DRIVE IT
Sally's thread http://67-72chevytrucks.com/vboard/s...d.php?t=563266
chasinhiway is offline   Reply With Quote
Old 11-15-2016, 12:44 PM   #3
67 chevelle
67 chevelle's Avatar
I have used fat mat , pretty much the same stuff as dynamat , but less expensive
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 11-15-2016, 02:09 PM   #4
Rich916
Rich916's Avatar
Fat Mat is a good product, i did the entire cab floor for about $70.00.
71 Short Step Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=429946
Rich916 is offline   Reply With Quote
Old 11-15-2016, 02:22 PM   #5
demian5
demian5's Avatar
What was the difference? I was thinking of doing that and over the gas tank.
"Work hard, use your vacation days."
1970 C15 GMC Long Bed
1986 C20 Scottsdale
1983 K2500 Sierra Classic Suburban 6.2
Instagram: C10sofOC
demian5 is offline   Reply With Quote
Old 11-15-2016, 03:51 PM   #6
Rich916
Rich916's Avatar
It made a very notable difference.I applied behind the tank and not on the tank. make sure you tape all the seams, the road and engine heat causes the adhesive to ooze out a little.
Old 11-18-2016, 08:59 PM   #7
frenchy51
frenchy51's Avatar
X2-Don't scrimp-USE DynaMat
1972 Highlander PAC B 400BB-SOLD
1974 K5 Blazer-6.0 swap
1974 C20 Long Bed 454
1977 GMC HeavyHalf
several adopted orphans
frenchy51 is offline   Reply With Quote
Old 10-10-2017, 01:48 PM   #8
skinnan
you need a better radio...
skinnan is offline   Reply With Quote
Old 10-10-2017, 02:22 PM   #9
cleszkie
cleszkie's Avatar
In my Blazer, I lined the entire tub and inside my doors with Fat Mat. Worked great at sound deadening with carpet over top. But not so much with heat reduction inside the Blazer. To solve the heat issue, I lined a portion of the engine compartment side of the firewall with Kevlar heat shielding, and ran this all the way under the tranny tunnel over the transmission. I also added more Kevlar heat shielding on the underside of the bed floor between the mufflers and the bed floor. This heat shielding greatly reduced the radiant heat that was coming through the firewall and up through the floor. No more warm/hot floor, and the A/C works much better without having to fight the radiant heat.
cleszkie is offline   Reply With Quote
Old 11-15-2016, 12:42 PM   #10
ga-stepside
ga-stepside's Avatar
I've used FAT MAT http://www.ebay.com/itm/FatMat-100-S...8nqEcA&vxp=mtr on two cars and am very pleased with it. Still not cheap but cheaper than Dynamat. It comes in differ amount if you don't need too much.
1967 C10 Step side
1970 AMX 390
1977 Datsun 280Z highly modified with '95 LT1 power
ga-stepside is offline   Reply With Quote
Old 11-15-2016, 04:10 PM   #11
chasinhiway
Do a google search fatmat vs dynamat. There is some interesting comparisons.
http://www.caraudio.com/forums/gener...d-dynamat.html
Old 11-15-2016, 04:58 PM   #12
RRR18
RRR18's Avatar
Fat Mat was on mine when I bought it. Compared to my buddies old truck without any deadener it's night and day. I won't ever go without it again. I've used Dynamat before for car stereo things in the past and it worked as it should have also.
'67 BAD IDEA
Follow on Instagram https://www.instagram.com/rtimes3c10/
Ryan
RRR18 is offline   Reply With Quote
Old 11-15-2016, 05:29 PM   #13
bigpaul
bigpaul's Avatar
I have the fat mat in my cab and I wonder if I need insulation also. Any thoughts?
bigpaul is offline   Reply With Quote
Old 11-15-2016, 08:46 PM   #14
NC_John
NC_John's Avatar
www.sounddeadenershowdown.com
It's a full package. Hushmat/dynamat/fatmat is only part of the equation and it is a waste of money to do an entire interior with it.
Did it in my '70 with 40 series flowmasters dumping right behind the cab and it did a great job.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 11-16-2016, 08:07 AM   #15
69 c10 - dsm
I just recently purchased "Noico Black 80 Mil 36 Sq Ft Car Sound Deadening, butyl automotive deadener restoration mat and Noise dampening insulation" from Amazon and I have a buddy that uses "road kill" purchased at Walmart.
69 c10 - dsm is offline   Reply With Quote
Old 11-16-2016, 09:41 AM   #16
70cst
70cst's Avatar
http://www.b-quiet.com/?gclid=CPGzor...FQGUaQodar4CdQ
I used the above company on the Circuit Rider - worked great.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 11-18-2016, 07:31 PM   #17
Rex'69
You can buy peel and seal at home improvement stores (lowes in my area) for a fraction of the price as fatmat and it's the exact same thing (except it doesn't say fatmat on it). I found this out after months of research. Another good thing is you don't have to order and wait for it if you run out. As far as insulation you can get frost king duct insulation at the same store. I have my entire daily drive covered in both and the difference is night and day. I've installed custom stereos since high school and wouldn't use the stuff if it didn't work.
Rex'69 is offline   Reply With Quote
Old 11-18-2016, 07:40 PM   #18
Rex'69
You can buy peel and seal home improvement stores (lowes in my area) for a fraction of the price as fatmat and it's the exact same thing (except it doesn't say fatmat on it). I found this out after months of research. Another good thing is you don't have to order and wait for it if you run out. As far as insulation you can get frost king duct insulation at the same store. I have my entire daily drive covered in both and the difference is night and day. I've installed custom stereos since high school and wouldn't use the stuff if it didn't work.
Old 11-18-2016, 09:15 PM   #19
Shinysideup
Shinysideup's Avatar
DONT USE THIS GARBAGE. It melts in the heat and smells. It may LOOK the same but isnt dynamat.
Shinysideup is offline   Reply With Quote
Old 11-18-2016, 09:24 PM   #20
Rex'69
Not trying to argue with you but have you ever seen it melt? My truck is black and it's get over 100 degrees in the summer and nothing has melted in four years. I know this because I had one of my door cards off to replace a speaker and everything was stuck on there same as the day I put it on. I get that people like dynomat but there are a lot cheaper products that work just as well. If you have any first hand experience in it failing I'm all ears.
Old 11-18-2016, 10:14 PM   #21
Dustytrix
I agree Rex I have used it on 1 car and 2 trucks, never had it melt or smell. I do tape the seams with aluminum tape though. I did my 67 for about $30. Thats hard to beat.
Dustytrix is offline   Reply With Quote
Old 11-19-2016, 12:00 AM   #22
Robznob11
Robznob11's Avatar
Peel and stick duct insulation...18$ a roll. I agree that's hard to beat. Put the regular auto pad under the carpet....bingo....
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 05-31-2017, 10:52 AM   #23
demian5
demian5's Avatar
I have it over my generator enclosure in my toyhauler and it has done well, no small or melting.
1986 C20 Scottsdale
Instagram: C10sofOC
Old 05-31-2017, 10:56 AM   #24
Robznob11
Robznob11's Avatar
Works good for me!
LED TAILS
Old 10-03-2017, 04:33 PM   #25
forestb
forestb's Avatar
Did any of you use a heat shield also or do these products do double duty?
forestb is offline   Reply With Quote
