Lq9 cam suggestions? Pick one please
I have a lq9/4l65e/241 going in my rig that's in my signature
K5 One tons 4.10 gears 37s Schoenfeld headers with 2.5" dual exhaust My 6.0 lq9 drive train is out of an escalade. I have to pull the heads so I might as well change the cam. I also have 243 heads I can install if you guys feel it's necessary. So here's the cams I have picked out. (Stock stall trans) Vinci chopper 210/218 .551/.551 lift 112lsa Eps truck torque 1 214/220 .600/.564 lift 112lsa Btr truck cam 3. 218/224 .553/.553 113+3lsa
K5, 14B/60, 6" LIFT, 37" NITTO RIDGE GRAPPLERS, KMC BEADLOCKS, ORD CROSSOVER, 6.0 lq9/4l65e/241 in progress ![]() |
meowMEOWmeowMEOW
Re: Lq9 cam suggestions? Pick one please
Cam 3, and its also on the best cam core.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
thats the cam im leaning towards.
You don't have them listed but you may want to take a look at Cam Motion as well. They have drop-in cams for the 6.0 truck engines.
Another option is to call some of those vendors and have them custom spec a cam for your specific application. Most are happy to do it and it doesn't cost much (or anything) depending who you go with. That's the route I'm going with the LS2/4L80E swap in my K5. |
I ended up buying the Brian tooley cam. Stage 3
A note on the heads . If you are pulling the heads I would use the 243 being you already have them ( both in stock form ) . There is some advantages over the 241 . If not pulling the heads I would leave the 241 on . They are a decent head with a little bigger chamber than the 243. The 243 will give you a little more compression which is a good thing in that engine. 241=66.67cc , 243=64.45 . The runners are 241=200cc , 243=210cc . You should be around a 10.5 to 1 with the 243 .
Also why do you have to pull the heads ,is there a problem . Do not know how many miles is on your engine but if the heads come off I would put some new lifters in as well if north of 150,000 miles . Also you are pretty much at the max spring lift for stock valve springs with that cam. I would also consider a spring upgrade . Your lifters and cam will thank you in the higher rpm range . Just some food for thought . |
#7 | |
![]() Join Date: Jul 2009
I may have misread the original post, but I think the 241 refers to an NV241 transfer case. Wouldn't an lq9 normally have 317 heads? Either way, 243 heads would bump compression and I agree with your advice. I'm just trying to clarify. |
yeah guys i am putting my 243 heads on the 6.0.
the cam i selected from BTR came as a kit with the correct valve springs. the motor has unknown miles so i am going to put bearings in on lower end while its torn down.
With the 317 heads, LQ4 is 9.4 (dished piston), LQ9 is 10.1 (flat top) so you'll get a bit more compression than listed in the zillion LQ4 posts about the 243 heads. Ought to put you in the neighborhood of 10.9. Just something to think about if you haven't, but since you can get likely get 93 octane in MI, you'll probably be fine. Also probably something a competent tuner can handle.
#10 | |
