Old 11-19-2016, 07:00 PM   #1
dragn91
dragn91's Avatar
Help with some wiring.
Im trying to go through my truck and clean it up a bit so i tore out the old power door wiring harness because im picking up a new set of manual doors and the wiring was butchered. I came across a couple things idk what they are one was laying on the floor i traced it up to an idiot light for the cluster but idk what one. the other is a aluminum thing hanging under the dash and id like to put it in the right spot. I also ripped out my f'ed up dash and headliner that was deteriorating and falling into my eyes.
http://
http://
Truck is an 85 k30 6.2 thanks for any help
dragn91 is offline   Reply With Quote
Old 11-19-2016, 07:33 PM   #2
dragn91
dragn91's Avatar
Re: Help with some wiring.
Also if anyone has a wiring diagram for a dual tank truck for the sending units to the gauge i need to figure out whats up with mine. The switch is m.i.a
Old 11-20-2016, 09:24 PM   #3
Low69CST
I uploaded what I think is the right diagram. Do a google search and a search here. There is ton of information on the dual tank setup.
'69 CST Short fleetside
Lowered, 400 small block, 700R4, 4 wheel disc brakes, front sway bar & rear camaro sway bar (in progress)
'87 V10 4x4 Short Fleetside
Quad Suspension and Dual Tanks
Low69CST is offline   Reply With Quote
Old 11-25-2016, 01:05 AM   #4
mitch1965
mitch1965's Avatar
I believe that the finned aluminum module is your wiper delay controller. It is usually mounted to the lower steering column.
'99 K1500 Tahoe, 2dr, barn doors - 350/ 4L60E, 3.73
'01 K2500HD Silverado Ext Cab - 496/ Allison, 4.10
mitch1965 is offline   Reply With Quote
Old 11-25-2016, 10:32 AM   #5
dragn91
dragn91's Avatar
Ok that makes sence the column has been swapped before i got the truck i noticed a couple things not attached to it right.
