Old 11-21-2016, 12:18 PM   #1
Scott76
Raise the rear an inch or so after a flip kit? Rake looks messed up.
I was running a 4/6 drop with McGauhys 2 inch drop spindles and springs up front, and a flip kit in the rear on my 79 C10. It looked cool as heck, but my front wheels rubbed everywhere and my header collectors scraped getting out of my driveway. I ended up swapping the front springs for some Belltech 1" drop springs, and it fixed all my issues except that it looks wonky now. It almost looks like the truck has a reverse rake. Seems like the McGauhy springs were much more than a 2" drop. I have a big block, not sure if that's a contributing factor, but the front of the truck probably sits 2-3" higher than it did with the McGauhys springs.
So as I see it, I have these options:
Install Belltech 2" drop springs up front and see if they're actually not as low as the McGauhys 2" drop springs. If they are, Get some 3/4 length headers and fab up a new exhaust system that's tucked up high. This is probably the best long term solution.
Leave the front of the truck alone and raise the rear of the truck up an inch or so. How can I go about doing this?
Scott76 is offline   Reply With Quote
Old 11-21-2016, 12:31 PM   #2
MikeB
MikeB's Avatar
Re: Raise the rear an inch or so after a flip kit? Rake looks messed up.
Air shocks? Or back to un-flipped rear, and use shackle/hanger kit for 4" drop?
But if the front is now too high, maybe the solution is another pair of springs. If the info is available, you'll need to know the installed height at xxx# load, as well as spring rate for your current springs in order to determine what you need.
Funny how one mod affects another mod affects another mod.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
Old 11-21-2016, 08:55 PM   #3
Tom
driving is in my blood
Tom's Avatar
McCrappys springs are well known to lower more then they advertise. I'd get some good 2" springs and start from there. Otherwise you'll need some shackles or hangers to raise the rear. FYI I've always thought "leveled" trucks [2" lower in rear then front] looked wierd and reverse raked.
Old 11-21-2016, 11:00 PM   #4
Jay2Cor517
Jay2Cor517's Avatar
I had the exact same issue using a complete BellTech 4/6 Kit. I ended up attacking it on two fronts: 1) I bought 1" lower springs for the front and 2) I use two different size tires. The front tires are 245-40-20s and the rear tires are 275-45-20s. The tires are 2" in height difference. Go to the website tiresize.com and use the comparison function https://tiresize.com/comparison/
I hope this helps.
Everything that can be counted does not necessarily counts; everything that counts cannot necessarily be counted--Albert Einstein
Jay2Cor517 is offline   Reply With Quote
Old 11-21-2016, 11:29 PM   #5
Gmc.guy
Gmc.guy's Avatar
Same here. Levelled out does look funny sometimes. It doesn't help the rear wheel openings are smaller than the front too
-Cody
Gmc.guy is offline   Reply With Quote
Old 11-22-2016, 11:34 AM   #6
Scott76
Ahh. Makes sense, glad I'm not imagining things. I think I'll grab some Belltech 2" springs and see where I'm at.
No, it certainly doesn't. The difference in amount of the top of the tire that is visible makes it really stick out.
Old 11-23-2016, 07:49 PM   #7
Speeding Dakota
Speeding Dakota's Avatar
Instead of buying aftermarket front coils use factory GM big block coils and cut only 1 full coil off. It will lower the front but will maintain the spring rate that is required.
That's what I did on my setup (2.5" CPP spindles & 1 coil cut - flipped rear) plus running 255/45/18 front & 275/40/18 rear.
Speeding Dakota is offline   Reply With Quote
Old 11-24-2016, 11:21 AM   #8
UKNOWME
UKNOWME's Avatar
Do you have any pictures of how it sits now?
2018 Audi S5- wife's ride
1980 Chevy Scottsdale http://67-72chevytrucks.com/vboard/s...d.php?t=543511
1981 Chevy Silverado- in pieces
1964 Chevy c10
2017 Jeep Wrangler JKU
UKNOWME is offline   Reply With Quote
Old 11-24-2016, 11:29 AM   #9
Scott76
Old 11-24-2016, 02:12 PM   #10
rich weyand
rich weyand's Avatar
You look dead level to me. It doesn't seem like it because the fender openings aren't the same on these trucks, and lowering it emphasizes the difference.
When I raised mine, I raised it 2" in front and 3" in the rear to even out the fender openings. So the body line is actually downhill by an inch. I like the look.
Rich Weyand
1978 K10 RCSB DD.
rich weyand is offline   Reply With Quote
Old 11-24-2016, 02:14 PM   #11
Scott76
Yeah if I put a level on the bed side it's actually almost perfectly level. The problem is the appearance because of the wheel wells, like you said.
Old 11-24-2016, 02:17 PM   #12
rich weyand
You can 1" block the rear to get the look you want, I think.
Rich Weyand
1978 K10 RCSB DD.
Old 11-24-2016, 03:35 PM   #13
Nick_R_23
Nick_R_23's Avatar
I think more than anything you need a bigger tire to fill up that wheel well more. It would additionally gain you that extra inch to raise the rear up more.
Old 11-24-2016, 04:10 PM   #14
UKNOWME
UKNOWME's Avatar
A block will lower it more since he's flipped his axle
1964 Chevy c10
Old 11-24-2016, 03:46 PM   #15
evan
evan's Avatar
Cool truck but with the current setup it does look like you've got some weight in the back. Ideally, drop the front an inch and rebuild the exhaust so you don't drag it.
What are the wheel and tire specs? They don't look like they should be rubbing but wheel backspacing and tire width/height are a major factor there.
Evan B.
evan is offline   Reply With Quote
Old 11-24-2016, 05:07 PM   #16
Scott76
They're 285/45/18 at all four corners. When I originally was planning the build out I was into autocross pretty heavy and was going that route. I would not do it the same way if I had to do it again. Would go bigs and littles, drag race style now.
Old 11-24-2016, 05:41 PM   #17
evan
evan's Avatar
Yeah, that's a pretty wide tire for the front. It wouldn't be too expensive to get 2 narrower 15" tires. I'd do that, adjust the exhaust and then lower the front until you're happy.
Evan B.
Old 11-25-2016, 11:28 AM   #18
Scott76
I think a 15/18 stagger would look really weird. I will just go with a narrower front tire on the same wheel when the time comes to replace them.
Old 11-25-2016, 11:30 AM   #19
evan
evan's Avatar
Oops. I was thinking they were 15" for some reason. Yeah, good plan. Do some burnouts and swap the fronts to the back and put narrower tires on the front.
Evan B.
Old 11-26-2016, 10:51 AM   #20
HunterRotten
HunterRotten's Avatar
I made the mistake of buying a mcgaughys kit too and I've scraped up the underside of my new tubular arms on the driveway. My dad and I have been talking and we though upgrading to some heavy half springs would lift the back end just enough, and then raise the front with some belltech 1" drop coils. Any idea how that would sit?
HunterRotten is offline   Reply With Quote
Old 11-27-2016, 03:25 PM   #21
LT7A
Scott76, you raise a good question. I have been thinking about this on my truck but its a long bed. Might be the same for both tho. How about removing the overload spring in the rear? The thick one at the bottom of the spring pack. Would raise the back about 3/4 inch. Being a short bed you could probably remove a second leaf to get you an inch plus. Or cut half a coil off the front. Only expense then is time and maybe u bolts. Like the truck, BTW. And I'm actually a fan of having the same size tires all the way around on these trucks. How's the clearance with your 285s at the front's current elevation?
Old 11-27-2016, 03:43 PM   #22
Scott76
Overload spring has been gone from the get go. Good idea, though. The tires do not rub anywhere currently. They actually only rubbed with the shorter springs because the top of the tire would hit smack in the middle of the inner fender on bumps. There was never an issue with the hitting the outer edge when turned, etc. I did roll my fender edges, not sure how much difference it made.
Old 11-27-2016, 05:52 PM   #23
UKNOWME
UKNOWME's Avatar
How is removing leafs spring going to raise the rear suspension?
1964 Chevy c10
Old 11-27-2016, 06:02 PM   #24
Scott76
Lol good point, didn't even think that through
Old 11-27-2016, 08:02 PM   #25
LT7A
You're right. Once the axle is on top of the spring, removing lower leaves won't change the ride height. Have to move spring hangers down on the frame or do something like that to gain elevation.
