11-22-2016, 06:21 PM | #1 |
Brakd bleeding/Proportioning valve
Valve has a pin on the end and I hold that in w/ a "C" clamp while bleeding the brakes.Is this correct? Saw a thread s few days ago (can't find it) which says I should use a shim gizmo and loosen a bolt to slip it in and it goes under the mounting bolt,to hold the valve open?? I do not understand. Just put all new lines in and it is pulling to the right. Thinking; I will try to rebleed the brakes.
Thank you for your help. I mean (Brake bleeding) won't let me edit the title. Last edited by akart; 11-22-2016 at 06:24 PM. Reason: miss SP |
11-22-2016, 08:36 PM | #2 |
Moderator
Re: Brakd bleeding/Proportioning valve
You can use whatever you want to keep that pin depressed while you bleed the brakes.
The "shim gizmo" is GM Kent Moore J-23709 super special mystery tool. It's not rocket science to make one and the homemade version doesn't cost $20 + shipping. Try this thread---->http://67-72chevytrucks.com/vboard/s...d.php?t=722308
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
11-23-2016, 04:35 PM | #3 |
Great explanation and the link explains it clearly. Thank you!!
