Aluminum Diff cover - panhard clearance
Looking at the aluminum diff covers with the bolts to brace the main caps. Anyone used one of these on a trailing arm setup with a longer/not stock panhard bar?
I have a porterbuilt setup I'm installing an the bar runs from the dr side to the pass side at the trailing arm. I'm looking specifically at the LPW low profile cover #201-12T, It says on Jegs that it wont interfere with the bar on a lowered truck but I'm wondering if thats more for a stock bar that isn't as long? http://www.jegs.com/i/L.P.W./619/201...FRc8gQodLDEC6g
Paul '78 GMC Serria 15 Heavy Half. 361/NV3500/3.73. Former LWB NV3500 swap Trailing arm swap '98 ECSB Z71 daily driver -traded ![]() '03 burb. Family cruiser http://upstategmtrucks.com/ |
Re: Aluminum Diff cover - panhard clearance
Thanks! I would assume that the ultimate cover is thicker than the low profile one to so it should have a little more clearance on top of that....
Right. You should have a little more clearance with that cover.
