![]() Join Date: May 2016
What crossmember to use. Muncie M 21.
What crossmember to use. Muncie M 21. I don't have the bell housing that came with the truck. It had a three on the tree. The op put a GH 400 in it. I would like a crossmember that would allow me to run my exhaust up in the frame. Thanks for looking.
Re: What crossmember to use. Muncie M 21.
should be able to use the automatic crossmember with that trans
I know that the TH350 and PG cross members work on a Muncie in a Nova with out any modification at all. So if you have a TH350 unit you should be good to go.
Thank you for the replies. I will check into that.
I'm confused. How many different crossmembers were available stock?
The Muncie M 21. That I am using Was not available on these trucks. So I have to use one that will work with this transmission.
