11-26-2016, 07:56 PM | #1 |
67-72 vs 73-87 frames, were they the same?
apologies I was way too lazy to search for this, a body of mine has a 67-72 cab and front clip off a 2WD that I would love to put on my '74 short bed is that easily done, he thinks not much has changed in the 2WD short bed frames during those years
so a 67-73 2WD short bed to a 1974 2WD short bed |
11-26-2016, 08:24 PM | #2 |
67-72 parts collector,…
Re: 67-72 vs 73-87 frames, were they the same?
Totally different frame.
11-27-2016, 06:42 AM | #3 |
Wheel base is different and i doubt any of the body mounts will be close.
11-27-2016, 07:29 AM | #4 | |
Wheelbase is different and wikipedia says 73 was an "All new, clean sheet design"
So I would guess no. From my limited and not scientific experience, the earlier trucks are not as wide either, doesn't seem like anything remotely close to a bolt on affair.
96 Miata FM 2.5 suspension, roll bar, brakes, hardtop. 82 C10 Turbo LSx build in progress: http://67-72chevytrucks.com/vboard/s....php?p=7764896 |
11-28-2016, 11:38 AM | #5 |
Different but not "All new, clean sheet design" new...
The frame widths are similar. The front suspension x-members will interchange but that's about it. The wheel base changed & the kick-ups in the frames are different.
12-06-2016, 04:25 PM | #6 |
Not even close. Same for steering and front suspension.
As an example, my 82 C10 has larger A-arms and the same size center link and tie rods ends as a 67-72 C20. But unfortunately, the 73-87 C10 did a away with rear coil springs, trailing arms, and track bar. Also the 73-87 transmission crossmember is not dual exhaust friendly.
Mike 1969 C10 LWB -- owned for 35 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- sold 1981 C10 Silverado LWB -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
12-06-2016, 04:36 PM | #7 | |
My '74 came with the dual hump trans cross member (top one in the first pic below) which I have used with a stock manifold dual exhaust system and a Hooker long tube header dual exhaust system, and it works great in my long thread Restoring Rusty I think I lay out all four different styles of the 83-87 transmission cross members in my driveway and show you comparison pictures they have different ones for 2WD vs 4X4, they have a different one for the TH350 vs the TH400 etc. |
12-06-2016, 05:13 PM | #8 |
I had forgotten about the other crossmembers, but now I remember them from a post you did awhile back.
Wish I'd had the top one in your picture when I connected my exhaust pipes to my new headers! You can see why in the pic below.
