Old 11-27-2016, 07:12 AM   #1
LeesTruk
Refinishing vent window frames
I'm restoring a couple of vent windows for my C10, and was thinking of using powder coating instead of paint. Has anyone done this and found the coating too thick for the gaskets/glass to fit properly?
LeesTruk is offline   Reply With Quote
Old 11-27-2016, 12:25 PM   #2
68Timber
I know the pieces fit
68Timber's Avatar
Re: Refinishing vent window frames
It'll be fine. There was a guy that used to post here regularly, he powder coated all his.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 11-27-2016, 04:10 PM   #3
LeesTruk
Thank you, sir
Old 11-27-2016, 04:47 PM   #4
hatzie
Moderator
hatzie's Avatar
Wet paints are typically 0.5-1mil thick when cured.
Powder is 2-6mils for decorative or 6-10mils for more functional... This all depends on powder type and how skilled the person is at applying and curing the powder.
One mil is one one-thousandth of an inch... 0.001" so even a heavy powder will be right around 0.010" thick. The place you run into trouble is close tolerance bolt and rivet holes. You can clear them by hand with a light touch from a tapered ream if needed. The rubber gaskets shouldn't be seriously affected by a properly applied powder coat.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 11-27-2016, 09:16 PM   #5
Ric's/86
I did have a very hard time putting the glass back after (Powder Coating) ended up using windshield sealer instead of the gasket.
You can buy them new for $40.00 here is a link.
LEFT
http://www.usa1industries.com/produc...t=0&featured=Y
RIGHT
You can buy them with glass from the same place.
Good luck with your project.
Ric's/86 is offline   Reply With Quote
Old 11-28-2016, 06:03 AM   #6
LeesTruk
Thanks for the info Ric, but my C10 is an '80, and as I have recently found out (thanks to this site) there are differences amongst the years, though subtle. Enough that parts can't be swapped. I do have several complete vent window assemblies, now, to play with ('77, '80, '81). My concern was powder coating the whole framework, not just the glass frame itself. Because the rubber gasketing fits into a channeled groove, my concern was the coating filling the channel so that the gaskets would have no place to seat. I've had suspension parts coated before, and the paint can be quite thick. I'm not a body guy, so my only other solution would be rattle cans, and I'm not quite sold on their longevity/durability
Old 11-28-2016, 06:38 PM   #7
vht
They have hi temp tape, youcan tape off the channel where the glass fits. A friend does alot of powder coating and he has various widths of it. Good stuff.
vht is offline   Reply With Quote
