11-29-2016, 08:53 AM | #1 |
Transmission Crossmember
Hi I'm in the process of building a 64 c20 it's going to be bagged and I want to lay frame and I plan to keep the the manual 4 speed trans that's in it.
Has anyone modified the trans crossmember so It doesn't go below the frame or is there a company that makes one? |
11-29-2016, 11:55 AM | #2 |
Re: Transmission Crossmember
Depending on what you want to do, a flat bar or a tube can be built to suit your needs. For example the one I built for my 62 and TKO 600
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats http://www.cardomain.com/ride/332579...t-c-k-pick-up/ http://67-72chevytrucks.com/vboard/s...d.php?t=560081 |
11-29-2016, 12:50 PM | #3 |
he is talking I believe of modifying the crossmember under the bellhousing on the 63-66 trucks
ron |
11-29-2016, 05:55 PM | #4 |
Yeah I was talking about the Crossmember that mounts to the bell housing. I don't think a flat bar style will work with my trans because the parking brake is on the output shaft of the transmission.
