11-30-2016, 12:22 AM | #1 |
Project Started! Is my frame bent?
Started my project on my 68 shorted c10. Going to run full porterbuilt stage 3, 6.2ls3 4l75e drive train, Patina body. Same as everybody it seems right now... I have the truck all torn down to the frame and was getting ready to get sandblasted but noticed the frame looks a little tweaked. The truck doesnt show any signs of being in a major wreck but does have some bad body work done where it looks like it was dented in the back rear. (only downfall of the truck ) Also the firewall has separated from the cab floor on the passenger side. I have measure in a X pattern in the same spot and it is within a 1/8th of a inch. When I say it looks tweaked it looks like the back driver is sitting higher than the passenger. I will say that my jack stands are not perfectly level and it can be straighten by pick up on it. Is this normal? With porter built on the way I want to make damn sure its a straight frame before I go taking out cross members and installing.
[IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
11-30-2016, 07:19 AM | #2 |
Re: Project Started! Is my frame bent?
Frame pictures ? The amount of damage to the right rear bed wouldn't suggest frame damage ,Get the frame level and start measuring . Adding the 6.0 and all that suspension would warrant beefing up the frame to carry the extra HP and torque .
11-30-2016, 09:04 AM | #3 |
WOW! That is a clean truck! WELCOME to the forum!
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
11-30-2016, 09:11 AM | #4 |
Welcome to board from Maryland! I see you already have a helper too. A lot of times worn cab mount bushings will make it look like the frame is bent because the cab tends to sit lower on the drivers side.
Ray
72 Cheyenne Super (Purchased new by my parents in August of 71) Black and White |
11-30-2016, 10:21 PM | #5 |
Welcome to the site, you did an X did you do one for just the bed holes? I say it is ok. Also the floor looks like the spot welds were left off from the factory. Drill some holes there I bet with some vice grips you can pull those panels together then plug weld from the front bottom and cure that problem
12-01-2016, 12:00 AM | #6 |
the boat guy
I think the roadster shop makes a very nice rolling chassis for about $10k
12-01-2016, 01:10 PM | #7 |
From those pictures I doubt the frame is bent , if you are talking about differences in wheel well heights , many things can cause that ,old springs , and a hit may have tweaked where one of the bed crossmembers connects to the frame , shocks , exc , exc, exc
If you are talking cab heights , the old rubber cab mounts cause this all the time
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs 67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive 58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white 69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive |
12-01-2016, 02:46 PM | #8 |
All about them K’s
The passenger side of my fire wall was separated like that too. Mine was because of rust at the bottom seam where the firewall and floor plspot weld together. When the lower seam rusted out there was nothing keeping those side welds from breaking. Clamp it down and plug weld it back up.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
12-01-2016, 11:24 PM | #9 |
Did you find any extra spacers or holes on the body mounts? Any bumper mounting holes that had been ovalled or slotted? Your body lines in the photo look pretty good and the front bumper looks straight. If you didn't find anything out of the ordinary then it most likely is as good as it left the factory. Most body shops that are willing to ignore a bent frame are pretty sloppy with their methods of hiding the bent frame. You will see odd spacers and holes that have been torched out. Like my Burban. Congrats on scoring that nice slantnose 503 green truck.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
12-02-2016, 08:52 AM | #10 |
Why the porterbuilt , I could understand on an earlier i beam truck , these trucks handle so good , and have tons of aftermarket suspension stuff , are you looking for a "lay frame" truck ?
12-02-2016, 09:06 AM | #11 |
Hey Jmh68C10 ...
Just want to say ... to the forums and from Ohio
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-04-2016, 03:44 PM | #12 |
12-04-2016, 08:20 PM | #13 |
Since you have it bare, either take it to a frame shop, or check it for straightness yourself.
