12-01-2016, 05:11 PM | #1 |
Water temp sender question (location)
One of my next projects is to reconnect a few of my dash gauges that are not being used in lieu of an under dash set that I want to eliminate. My water temp sender is coming from the passenger side of the block with what looks like a coil covered line that actually passes water to the gauge (my speculation). I've read the threads on the best sender to get - can anyone tell me which is better, or will fit a proper wired sensor - the manifold or this block location? Thank you, Ned
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
12-01-2016, 05:48 PM | #2 | |
The Older Generation
Re: Water temp sender question (location)
If it is a stock engine check on the drivers side head between #1 & 3 exhaust ports to see if the original sender is there. The coil covered line does not pass coolant to the gauge. It is a Bourdon tube that is filled with a special fluid that is expanded by the engine temp and activates the mechanical gauge. LockDoc
12-01-2016, 06:20 PM | #3 |
Dude my 70 has 2 senders, one in each head, and they are both hooked up??? I haven't checked to see which one works for the gauge (gauge works fine).
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
12-01-2016, 08:12 PM | #4 |
Thanks for the help on this, guys - and to learn about that temp line. I will have to look when I get home, as I am pretty curious now.
12-02-2016, 01:47 AM | #5 |
Here is my drivers side. Looks like the port is plugged off
Posted via Mobile Device |
