![]() Join Date: Dec 1999
Electric Fans
What are some of the options that have been used that don't break the bank. And how did you deal with the shroud issue. All input is appreciated. Going with a serpentine belt setup from a donor '93 350 and don't think there is clearance to use the stock fan. Especially with the stock shroud. Thanks! All the information I have been getting to my questions of late have been extremely helpful.
Smitty '71 Short Fleetside Spring Valley, Ca. |
Re: Electric Fans
In for info!!
Re: Electric Fans
I know you asked about an electric fan but, i'm running the stock serp belt setup from a 95 (same basic setup). I went with a different clutch & 18" fan to fit the OE shroud. The OE fan for my 95 donor was 19" (too large for shroud)
Truck is 4x4, the engine is set back further than a 2wd but it also has a deeper shroud. Believe this setup would work for 2wd also. will measure OAL of setup from the block if you would like (can't until Wed. - out of state) I have run elec fans but I feel the stock shroud, engine driven fan / clutch setup performs better. fan clutch - CQ p/n 215168 (1/8" longer than original clutch) fan - Derale p/n 17918 18" reverse rotation (for serp belt setup) |
The Older Generation
Re: Electric Fans
I used a fan setup from a 2002 Toyota Camry on the '67 Panel Truck. Just a minor amount of trimming and made two small "Z" brackets to secure the top to the radiator frame. One of the bottom mounting holes lined up with a hole in the lower radiator frame and I drilled a hole in the frame on the other side to line up with the stock hole in the fan assembly. I used carriage bolts and bolted it all the way through the frame. Just go easy when you tighten them up. Pretty easy overall.... No shroud needed with this setup. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-05-2016 at 12:51 PM. |
Re: Electric Fans
#6 | |
Re: Electric Fans
LockDoc
#7 | |
Re: Electric Fans
#8 | |
Re: Electric Fans
My 1970 C10 ChassisFab LWB to SWB Build Thread |
Re: Electric Fans
I used Flex-a-lite Syclone fans. They were actually a bit too big, so I made a custom plate out of Lexan.
It turned out awesome. I controlled each fan with the FITech system. Had one turn on at 180, and the other at 185. Zero issues. In the picture of just the fans sitting on top of the radiator, they are turned the wrong way, making them look terribly oversized. But when they are turned 90*, they aren’t as wide, and fit excellent. They only overhung by about an inch on each side, and cover almost the entire radiator surface.
"If it ain't broken, fix it 'till it is!" Last edited by Extended Power; 08-20-2023 at 12:19 PM. |
Re: Electric Fans
I used a serpentine setup with a reverse rotation clutch fan setup. I was able to retain the factory four row radiator along with the stock shroud; I used a Derale fan blade I bought from Summit Racing, and a fan clutch from a '93 truck iirc. If you want, I can look up the part numbers for you, and get pictures. The only mod I had to make was to cut about an inch off the fan shroud, as it was a little too long. The serpentine setup is really nice, and the clutch fan is a great setup.
Old member
Dual Camaro fan setup. Works great for my LS6.0 it runs 180* all the time. 3 years and no problems at all. Fans kick on if AC is turned on and I wired a micro switch to cut them off at 25MPH they are not needed while at speed.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Electric Fans
Great information as usual. Will have to sort it out as things progress. The restoration shop has the rust handled and is now starting on the dents. Thanks again.
Re: Electric Fans
Lock Doc are there any other components I need to get when I pull the fan set-up.
B.W. is the clutch and fan that you are citing stock to this serpentine setup? The one I pulled looks exactly like the unit you show in the picture. Thanks again Smitty
Re: Electric Fans
No, the fan is 18" the stock fan is 19" & will not clear the shroud. I needed the clutch because the new fan had a different bolt pattern
#15 | ||
Re: Electric Fans
LockDoc
#16 |
Re: Electric Fans
good info here!
this might sound like a dumb question, but here goes..... when I go electric fan, what all needs to be done to delete the clutch fan so I can free up space? thanks fellas Barnabie
69' GMC LongBed- 350/4 speed "GeeMack" 72' C10 Longbed- 355/400 combo cut front springs and bagged rear on 18x10 GSI Drop member front and rear coming soon 00' Tacoma- Solid axle twin cases, 5.13's, ARBs on 37s 08' Roadking, 99' Softail, 81' FLH, 76' Superglide |
#17 |
Re: Electric Fans
Flexalite and only draws 21 amps
Fuzzy |
#18 |
Junior Member
![]() Join Date: Mar 2005
Re: Electric Fans
I did this back in 2008 and I have never had a problem with this set up. I drive and race my truck a lot in the summer. 100 Deg day no problem. I installed it in my big block fan shroud and used a painless temp relay on at 185 deg off at 170 deg. if I did it again I would put the tab through a slot in the bottom of the shroud insted of the top.. live and learn..
Jeep Grand Cherokee Radiator Cooling Fan Assembly for L6 4.0L Make: Jeep / Model: Grand Cherokee/ Year: 2000 Price: $56.60 Item: AM-21731749 ![]() ![]() ![]()
72 cheyenne super BB402 TH400 Air Tack Tilt Posi P/S P/B AM/FM 12.96 @ 101.82 mph 60ft 1.82 12.39 @111.33 With a 180 shot nos 69 Camaro RS http://s94.photobucket.com/albums/l117/fdelcoglin/ email fdelcoglin@hotmail.com |
#19 | |||
"I ain't nobody, dork."
Re: Electric Fans
Did you use the painless temp relay kit with the 30 amp breaker? Or just the relay itself wired to the unit. By chance did you put an "over ride" switch in line so you could turn the fan on manually if you want to? Gary
#20 | |
Re: Electric Fans
1970 C10 Short Stepper with 71/72 front clip. |
#21 | |
Re: Electric Fans
Is that the stock 67-72 C10 shroud? |
#22 |
Re: Electric Fans
OK so yes that looks like the factory shroud which is 20 opening. So those mount tabs must stick out quite a ways. Anything else I should know because I'm going to do this mod. I really like it.
"72" Red CORVETTE 4-speed 350 "70" Chevy Short Bed early stages of resto. Edel 600 cfm carb Weiand Stealth Intake HEI shorty Headers 4/2 Drop 295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners. "CHEVY RULES" ![]() |
#23 | |
Re: Electric Fans
http://67-72chevytrucks.com/vboard/s...d.php?t=254617
#24 |
Re: Electric Fans
Do you have a part number for that? Maybe a link?
Thanks, -klb
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
#25 |
Re: Electric Fans
Flexalite #295
Fuzzy |
