12-05-2016, 03:55 AM | #1 |
4.8/4L60e purchase
Just picked up a 4.8/60e. I was able to drive truck before pulling. Transmission seemed to shift fine. Motor smoked a little when getting up to speed. This setup has 350k on them!
I am thinking that heads need rebuilt and bottom end needs to be re-ringed at least. New oil pump, gasket set, timing chain, and ARP bolt kit.... Anything else you guys would do? Thanks!
Jimmy Hoelzel |
12-05-2016, 11:52 AM | #2 |
meowMEOWmeowMEOW
Re: 4.8/4L60e purchase
Hard to know until you get the block apart. If you can just ball hone it a bit you can get away with a re ring. If the cylinders have any scoring on wall, its best to get it into a machine shop and see if a hone will sort it out, or if a small over bore is needed.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
12-05-2016, 12:08 PM | #3 | ||
"I ain't nobody, dork."
If you're that far into it... why not have the rods and crank checked and install new bearings. Peace of mind...
Gary
12-06-2016, 04:49 AM | #4 | ||
Where is everyone ordering rebuild parts for LS motors from...Summit, GM???? Will defiantly be putting new bearings in it
Jimmy Hoelzel |
12-07-2016, 01:03 AM | #5 |
When i had trouble with my 2001 5.3 from the junkyard, i needed to bore the block because of rust pits. I happen to check on ebay and someone was selling gm's extra stock and i bought a new gm 4.8/5.3 block with cam bearings already installed for $199.00 plus shipping in 2014. In my hands was $324.00, stock perfect bores ready to go. I believe jegs or summit picked these up and this summer they had them for $3??.?? and free shipping, what a deal.
12-07-2016, 01:43 AM | #6 | |
Jimmy Hoelzel |
