Old 12-05-2016, 04:17 PM   #1
c673986
72 Hazard Light Problem Leads
I've been going thru a 72' (just got 3 months ago) getting it ready to get registered. My last item was getting the hazards working. The relay for the hazard flasher was missing, so i put a new one in there. Upon doing this and turning on the hazards, I lost all rear lights. Running lights, brake, etc. They are also now dead after pulling the flasher relay out. The front hazards did blink though when it was in. Previous to this, I had replaced the headlight control and the floor dimmer switch and everything was working.
Thus far I have looked at the back of the fuse panel for shorts and inspected the turn signal switch wiring. I don't see any blown fuses. Any ideas appreciated.
c673986 is offline   Reply With Quote
Old 12-05-2016, 05:04 PM   #2
'68OrangeSunshine
'68OrangeSunshine's Avatar
Re: 72 Hazard Light Problem Leads
I'd suspect the Turn Signal Switch unit. Most of those wires run thru there and, it's easy to develop some weird shorts with a lot of connections in a tight spot that gets a lot of movement. Did you test the bulbs for continuity? Sounds like a short in the Hazard circuit fried the bulbs downline.
Old 12-05-2016, 06:28 PM   #3
c673986
I'll check some bulbs tonight and begin tearing into the turn signal switch. Thanks '68OrangeSunshine
